Newbie Question 18650 Powerbanks
Hello,
DIY powerbanks
Questions- What is the best 18650 batteries for making your own powerbanks, I bought shells from China based store on the internet.
thanks
Just be aware that video is from 2012 so whomever sold those could be gone by now.
Obviously still a possibility but who would know unless one does the same operation.
I've had 18650's from Ebay that work just fine for long periods of time now.
Here is the same brand name last year as 8 years ago, Ultrafire.
It is labelled with 3 times the capacity of Name Brand more expensive batteries but it is a lie. It tested at 1163mAh.
Another cheap lightweight 18650 Chinese battery was opened 3 years ago and it was almost empty inside.
Another cheap Chinese 18650 battery measured 353mAh.
And another, and another and another.
High quality ones, brand type.
Possibly low to no quality.
With many companies outsourcing the manufacturing of products, how can I ever know that its not a cheap Chinese "knock-off".
I checked ebay and find almost the exact same shells, are there any known high quality companies (or brand names) that produced high-end shells?
Samsung (Korea) and Panasonic (Japan) make high quality 18650 cells and real ones are sold by reputable dealers. Horrible knock-offs are sold by '"sellers" on all the Chinese websites. Frequently the fake one has less weight but looks better than the real one.
so....is weight (of the 18650s) the best way to know if its fake of not?
I bought Samsung 18650 25R, but I still get barely one recharge of my iPad (8 cell charger)
How is your powerbank constructed? A single 18650 cell with a USB powerbank adapter PCB (charging the 18650 cell, delivering 5 V on a USB port)?
The Samsung 18650 25R cells have a capacity of 2.5 Ah @ nominal 3.7 V. That's 9.25 Wh. You may be able to use ~ 80 % thereof (to prevent deep discharge of the cell and includibg losses of the step-up converter). That leaves you with ~7.4 Wh for charging the iPad.
An iPad battery I found has 6.6 Ah @ 3.7 V, equivalent to 24.4 Wh. Your single 18650 cell could charge this iPad battery by ~ 1/3 of the capacity.
You will need at least 3 or more 18650 Cells of this type to fully charge this type of iPad battery.
Numbers will vary depending on your specific iPad.
