Someone recommeded that I should use a 12V LM2940CT which is a low dropout regulator and specially designed for automotive use. Datasheet available here
I've calculated that with this 12V regulator the max power loss in watts is 0.84W (assuming max input voltage=14.4V, output voltage = 12V and current draw = 0.35A). So based on the datasheet, seems like this regulator has a higher operating temperate so a 0.84W power loss I am assuming will not need a heatsink.
Can anyone kindly confirm for me if this is the case? I am now more for the option of going for the 12V LM2940CT but would like opinions.
Thanks in advance
Thanks in advance
