PNP and NPN are pretty darn close to the same.Hi Adam,
Thanks for that breakdown, I think im following along for the most point, Im only really familiar with NPN transistors. Is the base not connected to the LED output on my LM3914? Therefore not getting 24V to begin with?
I may be being a complete ditz here so ill appologise in advance.![]()
The base still goes to the output pin on the LM3914, and will get whatever the output voltage is from this chip.
Adam's suggestion is to use a resistor between the LM3914 and transistor to limit current flow. Transistors are current driven and have such a high gain that you won't need to pump a ton of current into them (Or sink current from them) to be able to control the lights on the Light Tower you have. The additional pull-up resistor will help switch off the transistor at a greater rate as well.
What kind of experience have you had with the NPN transistors?
