K
Kevin Van Sant
I've posted this to a couple of honda forums but I thought I'd try a
couple of electronics forums too. Thanks for any help.
As a follow-up, I decided that blue and red were both (+) so tied
them together to the (+) lead. Black was ground, green was door
switches. I wired it up this way and the map lights work, the
original dome works, but the new dome blows the fuse when I turn it
on. The new dome is what's related to the blue wire (if you look at
the picture it should be clear) So evidently I can't just tie it to
the red, although if I exclude it there is no (+) lead to the new dome
light.
Can anyone figure out how I might wire this differently? Thanks.
I undertook my project of adding a map light assembly into the
headliner of my 98 civic LS today. I had to remove all the upper
interior trim to pull down the head liner, but it wasn't too bad. I
mounted the map light assembly and have put everything back together.
I haven't figured out the wiring, maybe someone here can help.
My Civic LS 4D is a '98, the dome light has two wires only. One leads
to the battery + , the other comes from the door switches. (I have the
'98 wiring diagram) The grounding comes from being screwed to the
metal frame of the roof.
The map light is from a 2001 Civic EX 2dr. There are 4 wires (see
picture)
http://img168.imageshack.us/img168/4031/maplightyg5.jpg
From looking at it, I'm thinking black is ground, red is (+), but
there is still blue and green. Green is possibly for the door switch
lead, but what about blue which is tied into yellow (thus tied to
white)?
I have to make four wires become three. I'm either going to have to
tie two or leave one out. Anyone have any clearer idea of this than I
do?
light.
