Sir FMA . . . . .
Well . . . . .thanks a lot . . .you DON"T even give a brand or model of this unit !
And you need more range ? So, WHAT is your present max range attainable ?
In just examining your photo, for what is able to be seen.
I am seeing the right sides wiring clutter from the Li Ion "mylar bag" battery that the unit uses . . . .
Definitely, no desire of the placement of the RF aspect of components over in that area.
Now, up at right top, we see a somewhat blasé cylindrical time base xtal, that would relate to
the U2 u/P I.C. just below it
( This unit sure ain't gonna be clocking at Superfantastophenomenostupendooutstandocategorical warp speeds ! )
That is being the brains for the unit and its basic programming is being stored in the U3 . . .24C02 eeprom.
That only leaves the 16 pin U4 ( ? are any readable ID #'s on its top ? ) as being the FM transmitter in a chip, with some probable assist / ancillary
RF discrete components being hidden in that totally non viewable area, just to its left.
But, in "reading the board" I would be most suspect of FM RF output to be from its pin # 16 to that 330 Ω load resistor to board ground plane.
73's de Edd . . . . .
Weight Watchers . . . . .
I ate salad for dinner. . . . . mostly just croutons & tomatoes . . . really just one big round crouton covered with tomato sauce and cheese.
FINE, it was a pizza . . . . . . ALL RIGHT ALREADY ! . . . . . I ATE A PIZZA !
