Sir Blaine . . . . .
Replacing the whole board prices out at ~ $141 and some supply places are saying "out of stock" or unk time of availability .
Just "hoping" to find and buying that
SAME identical transformer or finding another one on a used board to pull the transformer unit from it . . . is absolutely being a rats ass chance in hell.
Do you have the techno skill to analyze the wiring to the primary of the transformer.
In going on my 99 99 / 100ths suspicion that the 4 leads on the primary are for two windings on
the primary , each for 120 V operation and that they are
BEING tied in parallel to have a 120VAC
a la Canada . . . operational line voltage connectivity in your situation.
(Otherwise, they are arranged in series for use in 220VAC operational countries.)
I am only seeing two terminals on the secondary . . . . indicative of a single low voltage secondary winding . . .that's GOOOOOD !
On the frontal panel display, it is using minimal power and on our viewed side of the board, the two white relays and
THE heavier BLACK relays 12VDC coils pull the most power required by the system.( Minimal)
Your power transformers low voltage secondary feeds into the D14-15-16-17 power diodes to create a pulsating DCvoltage to be smoothed to and stored in C1 as pure DC and that will be the main supply voltage for the relay coils with a tap off . . . used to feed to the adjunct U1 for a sub power supply, it is probably going to be a 9-6 or 5VDC regulator.
Go by its part number numbering of . . . . . a 7805 for 5V . . .7806 for 6V . . .7809 for 9VDC.
Take a DVM meter in DIODE test mode and confirm that all 4 diodes . . .D14-15-16-17 . . .are giving good diode junctrion readings of ~500-700 millivolts . With no shorted 000 diodes.
In looking at the "boiled" winding of the transformer, its being on the secondary end, so I'm wanting to think that AC overvoltage / or power spikes coming in and shorting a diode(s) which then severely overloaded that winding and the pimary responded by opening up either of its primary windings or an internal thermal one shot cutout . SO be
SURE of those 4 diodes, as I'm expecting problems there.
My bet is that a conventional transformer of 120VAC input and 12VAC @ 1 amp output rating would be equivalent to what you have . . . or a 2A at the absolute most.
The C1 capacitor is only letting me get a peek at its side marking of ? 25 ? VDC or ?16 ? VDC, with only half of its numbering showing.
- Feed back its capacitance and voltage rating for confirmation.
You can (unfruitfully) search for an
case and terminal configuration at Mouser or Digi-key,
but will probably have to use some flying wire leads at points.
I personally would be using one of my several 12V@ 1 A/ or / 2A "FILAMENT" / "CONTROL" transformers (au gratis), collected from decades past, and then routing its wires to the PCB holes.
If you are a electronic person or have acquaintances that have some equipment, you could initially hook 12VDC into the C1 and test out with a variable DC supply set at 12VDC, as the display u/p will be run with its own clock oscillator . . . and is not being 50/60 cycle dependant.
If you do not want to have to "buy it to try it" and have some McGuyverish DNA flowing thru your veins.
I can give you that type of alternative . . . . if you happen to have use of :
- A doorbell transformer from your attic and an incandescant table or pole lamp, using a rotary, continously variable dimmer control.
or a
- 12 V car battery and a 10 ohm 5 watt resistor (or series/parallel /push pull / tandem/whatever) interconnects of several higher values to end up with that required 10-12 ohms of resistance
or
- Scotch tape , 4 toothpicks and a clarinet reed.
What say ye . . . . .
73's de Edd
