Hello, here is my problem. I am buying two (2) TurboChef Fire Pizza Ovens (spec sheet attached). I want to know what kind of generator I would need to power them both up and run them continuously safely. My preference in generator is the Honda EU class for its low noise levels but any other model would do should I have to change based on what my needs are (All Honda Models spec sheet attached). I obviously still need enough juice to power up two 50inch LED TV's, a few refrigerators, AC unit, and exhaust fans, but in all honestly that a bit easier to figure out since they use 110v. My question is:
What would be the most cost effective way to make this ALL work smoothly? Would I possibly need 2 generators to make this work?
I think it is related with horse power
but not sure how?
please suggest me a generator or advice me
I like if you suggest because I am going to buy it
I can't add honda generators.pdf file because it is large.
however tell me how to select it?
should we consider the starting wattage of all devices or normal one?
but not sure how?
