Hello all,
I think I would like to use this valve (http://www.electricsolenoidvalves.com/1-4-12v-dc-electric-plastic-solenoid-valve/) to open and close 1/4" chemical lines using 12 volts or less since it will be powered by a marine battery. I have found this valve to use for my prototype, but I'm unsure how to hook it up. Do I need to use a relay or an "h" gate to open and close it?
I've been looking on the web, but the more I read, the more unsure I get as to what I need. I also see valves of this type that are "normally closed", (http://www.electricsolenoidvalves.com/1-4-12v-dc-electric-plastic-solenoid-valve/) but not sure if these would be better or require fewer components to operate.
The liquids are cleaning agents that range from alkaline to acid and they seriously affect the rubber gaskets, plastic and metals of the valves I currently use. So, I am looking to use inexpensive valves since they will probably need to be replaced once or twice a year. I would only need each valve to be open for roughly 3 to 5 minutes at a time to disperse each liquid, so maybe a "normally closed" is the type of valve I need. I'm not sure. Don't NC valves need constant power to keep them open? Does this require a special circuit so that I don't have to "hold" the button "on" while dispersing these fluids?
And finally, how would I set this up so that I can switch chemicals or combine chemicals from a distance with a remote control? How can I get my remote to open each valve (4 - 6 valves total) with one button and then close the valve with a different button so that I can actually know if it's open or closed. Is this a 4 to 6 channel operation? Any help would be GREATLY appreciated and thank you for your time and expertise.
Totally confused and frustrated.
