Den torsdag den 17. oktober 2013 21.44.29 UTC+2 skrev Joerg:
Lasse Langwadt Christensen wrote:
Den torsdag den 17. oktober 2013 19.59.19 UTC+2 skrev Joerg:
RobertMacy wrote:
Sorry to post here but can't gain access to sci.electronics.repair for
some reason
I need 1/4 inch TIP/RING/SHIELD plugs with FULL METAL HOUSING! and small
diameter shoulders.
I went to MusiciansFriend which looked good, but their website won't
work on our systems, so called, described what I needed, convinced they
understood, ordered parts, promptly received package to find,...wrong
connectors! only have the tip and shield, a mono plug.
I need to replace full metal housing ones [which from descriptions
MusiciansFreind also carry], but these connectors are too wide and when
inserted into the row they not just touch each other, but prevent good
seating by forcing the physical position to be wonky. PLUS! and this is
really important, within a year their internal plastic parts simply
crumbled away making EVERY connector fail, cable falls out of housing,
retention of anything lost. These were those highly touted, somewhat
expensive metal ones which have a comfortable grip when removing from
the chassis jack.
So anybody know a good [inexpensive] source for 'stereo' guitar 1/4 inch
plugs with tip, ring, shield [for shielded twisted pair cabling] with
FULL metal housing? yet, rather small gripping diameter?
This is usually "the good stuff" but not cheap:
http://www.sweetwater.com/store/detail/TRSCableCon/
Here is a right-angle version:
http://www.sweetwater.com/store/detail/TRSMRAConnSW/
Good shop, we've ordered from there for our church.
it has (at least the right angled has) that useless crimp strain relief
this is the good stuff:
http://www.neutrik.com/en/audio/plugs-and-jacks/px-series/
and the price is about the same at mouser
I've used Neutrik in a design last year, good stuff, and I would have
recommended these. However, they bulge out at the cable end and that
looks like the issue Robert had.
Yes the "normal" ones (C type) are wider at the cable end,
PX is "slimline" only 14.5mm
