Sir Derik Sabel . . . . .
My crystal ball had already glowed up and told me that he was wanting to use AC . . . . . PLUS the all empowering
addition of
UNIVERSAL, gave the additional Carte Blanc on the two options wiring scheme.
I rapidly used a stock photo for the second photo on the first go around.
This time I carried on the top photo’s scheme and, using both of them, I arranged so that the hookup would reflect using the same numbering picks that Sir Kelly used in referencing.
That has the top schematic agreeing, per-Z-actly, with one of the hook up options.
On the lower schematic, it only requires that one (BLUE) wire be moved in order to get into the other hookup option.
My initial add on of the RED and YELLOW X’s was for you to inspect and see if the two viewable RED and YELLOW wires made short direct connections between their (X) points .
Since I wanted you to see if the manufacturer had already made them.
Consulting the schematics you see that C!-B1 and B2-A2 are static connections and remain the same in both options of operating modes.
Sooooooo basically, now, you need to see if an ohmmeter . . being .used in its low ohms range . . . shows any connectivity being present between :
A!-A2 -----to------B1-B2
Then
B1-B2 -----to------C1-C2
Then
A!-A2 -----to------C1-C2
If those are not connected . . . then the manufacturer left you a blank slate, with you then doing the inter connecting for the two options shown with the schematics.
Motor run direction would be another aspect, if DC operated, just a swap of DC supply polarity applied.
If on AC, it’s just a matter of winding phase reversal.
We just wait and see how your 50/50 odds work out . . . . . .
Further techno aspects available . . .2nd and 3rd points of coverage:
https://www.electrical4u.com/compound-wound-dc-motor-or-dc-compound-motor/
Now, one thing that I would additionally be interested in knowing is the horsie powders, or fraction thereof, and the wattage spec given for the unit.
Also. its intended use / application, as 5000 is revving it up quite a bit, unless it’s just being a fractional hp unit.
HOOK UP . .ILLUSTRATION Parte II . . .Deja vu
73's de Edd
