Hello,
I am trying to hook up multiple LED's to a PC power supply. I have all of the resistors pre-wired into the LED's already and basically just need to get power to all of them. There's around 15-20 of them and they are going to be powered by 12v DC coming from the PC power supply.
Initially I was going to use a breadboard but the solderless ones aren't for a permanent connection. I was thinking of using something like a barrier strip where each side is connected all the way down instead of each one separated. This way I wouldn't need to solder anything and could just screw each connection down, then screw in the power supply into just one connection on each side of the strip.
Would this work and is there such a thing?
Thanks for any help!
