Logan W said:
I have a DMM which I got a while back for $20 or so, from Jameco.
Lately, it has been giving me incorrect readings - when the test leads
are not connected to anything, it will say there are 800v, and this
does not go away when the test leads are detached. If I open up the
case, then it works normally, and if I do not have the back fully
snapped in, it works, but as soon as I do that, it starts saying 800v.
<a
href="
http://jameco.com/webapp/wcs/stores...toreId=10001&catalogId=10001&productId=119212">Here
is the multimeter I bought.</a>
Does anyone have any ideas on how I can fix it?
DMMs frequently have a foil shield that helps to protect the instrument from
outside interference. These foil shields can sometimes make contact with
the circuitry and cause strange operations, such as you are experiencing.
When you open the case, make sure there are no holes in the shield that
aren't supposed to be there, caused by parts of the circuit board piercing
the foil.
Another thing to look for is a broken circuit board. Look at it under a
magnifier and see if there are any cracks. If you find any, that's likely
the cause of your problem. If your DMM has a multilayer board, you might be
able to fix it, but it's not likely to be easy. A soldering iron with a
very fine tip is mandatory here. Bridge the breaks in the copper traces
with strands of very fine wire (30 Ga wire-wrap wire is a good choice here).
Also,make sure that there aren't any foreign substances
(coffee/coke/beer/etc) that has found its way inside the case. If you find
any gunk of the sort inside, a thorough cleaning is necessary, the last step
being a flush with distilled water. Allow to dry completely ( an afternoon
of exposure to the warm sun should work).
As a final suggestion, you might flex the display (assuming that it's an LCD
display) and see if it causes your erroneous display symptom. If so, you
might have an intermittent contact by the Zebra connector, which is a
polymer strip of alternate layers of conductors and insulators. This strip
is placed between the display module and the PCB, and makes electrical
contact between the two. If that's your problem, you might try cleaning the
contacts on the PCB, the Zebra strip and the LCD module with pure (99%)
isopropyl alcohol. Be very careful with the LCD contact area.. no
scrubbing on it. just a few swipes with a clean soft cloth saturated with
alcohol.
Good luck with your DMM.
Dave M
MasonDG44 at comcast dot net (Just substitute the appropriate characters in
the address)
Never take a laxative and a sleeping pill at the same time!!
