I'm examining the electronics of my Rickenbacker guitars, and man o' man, most pots are WAY out of spec. But I've had a difficult time reading pot resistances and capacitor values. Finally, after much testing, I've pretty much concluded that my problem getting readings from caps (smaller caps, look more like large resistors; 0.047 and 0.0047 uF) is that the leads are insulated (as they should be) but it was a little difficult exposing bare areas of the leads to touch with probes; had to push back the insulation a little at each end of the cap. I finally aggressively pushed back the insulation to expose at least 2 mm of bare lead, and then I got seemingly consistently good readings rather than erratic or no readings at all. I figured that there must be some sort of thin coating (epoxy?) on the leads immediately adjacent to the cap. I don't know what to say about reading pot/ohm values (these Rick pots are weird; I may post a few results later).... which makes me think...
...that these "auto range" multimeters aren't the cat's meow, after all. I have a couple of cheap CEN-TECH meters that I got for free from purchases as Harbor Freight a few years ago; limited in capability, but OK (model 98025), at least for working on my cars. A couple of years ago I searched for a better meter that included cap testing and audible continuity. Coincidentally, I ended up buying another CEN-TECH (98674) because it seemed to get good reviews across the 'net (in spite of it being an ugly dark green monolith).
So, the more I use this auto ranging meter, the more inclined I am to think that the auto ranging feature could be the source of some frustration in getting consistent and accurate readings. Sometimes I think it's the contact of the probe tips not penetrating a layer of oxidation; I'm not sure, but the meter is not as responsive as I want. I really need to be sure that the readings I'm getting are truly consistent and accurate. I'm beginning to think that this auto range feature may contribute to inaccuracy, as it goes through its diagnostic value ranging routine each time I test; a short but annoying delay, with possible inaccuracy on top of that. I'm at the point where I can't trust my meter because of this.
What is your opinion of auto ranging meters? If you can appreciate the annoying quirks of auto ranging (or maybe it's just my cheap/$65 meter), the perhaps you can suggest a good non-auto ranging digital meter. I think I need a good reliable, bulletproof meter, with wide-ranging diagnostic sensitivities that include audible continuity testing and capacitor testing. This time I won't be afraid to spend a little more cash to get more reliability. It's OK to have to think a little and turn a dial....
