Hi new to site have some electronic knowledge but at present can't figure a way to cheaply carry out the electronics
Project A friend has a Motorhome where the Radio goes off with the engine turned off so can't sit listening to radio once parked up my idea is to have the radio wired permanently to van main battery time and Channel maintainance so channels are always where you kept them, Then to have the on/off for the radio through a two way switch on/off/on so that onsite flick the switch to habitation and then switch off or as driving then switch to main battery.
But here I am stuck as I would like to have telltale LEDs for each operation But can't think of a way to fit the LED so that it only work on the specific battery.
One thought but is it logical
Battery (A) through 10A fuse > Though an LED >Though position 1 on switch > through to the Radio but the electronic path to earth be viable as the 12v /10A going through the LED
Then Battery (B) as same
Thanks in anticipation
