Robert Baer
Dr. David Kirkby said:A friend of mine has bought a 21-seater coach with the idea of
converting this into a motor home. Although it is a bit over the top
(OTT) in my opinion, he wants a system that can
a) Stabilise the vehicle when parked so that wind does not cause it to
move on the suspension. i.e remove the effect of the springs in the
suspension.
b) Level the vehicle if parked on terrain with an incline.
He has asked me if I can design him a system to do this. He is quite
capable of adding hydraulic rams to do the mechanicle work, as he has
excellent mechanical skills and has built a kit-car and done other
related items. However, he has asked me to design a control system to
do this. He wants to push one button and it all work. I'm an
electronics engineer, with quite a bit of experience of using A/D's,
D/A's and microcontrollers.
He intends adding two sensors that can check if the vehicle is level
in two orthogonal (at right angle) directions.
I'd like some advice/guidance from anyone with knowledge of how such
systems might work - I belive they are available at a high price.
Someone has pointed out to me the turret on militrary tanks keeps in
one direction, despite the fact the tank moves on uneven terrain.
My thoughts to date have been
1) Determine from the angle sensors which of the 4 corners the coach
needs to be raised. Lower a ram in the corner most needing raising
until such time as it in contact with the ground with say a 1 degree
correction in the angle of the coach.
2) Raise the corner that requires the second most degree of correction
until there has been a 1 degree change in the coaches angle.
3) Do likewise for the second and third corners.
At this point each ram should be touching the road surface.
Then repeat the procedure, after which the coach should be level.
Another idea is the dead opposite of this.
a) Raise the corner of the motorhome that is already highest, so
making the motorhome in a worst position than originally. Then do this
for the second worst corner. and to this for each corner. This seems
more robust as an algorithm, but needs longer rams, which cost more.
I have nagging doubts about all these.
Do I need pressure sensors to be certain the rams are indeed touching
the surface on which this is parked ? What happens if the surface is
not very hard, and gives a certain amount? What effect would wind have
on this ?
I don't want to completly lift the motorhome, but likewise I do need
to be able to remove some of the give in the suspension.
Dave kirkby
Perhaps an atom bomb could be used to solve all of the problems in a
definitive manner.
