Hello i`m a newbie just joined
Hello I`m looking to build my own type of motorhome alarm .
The plan is to use about 16 car reversing sensor fix in the side skirts of the motorhome .
so this will detect people who approach the motorhome at night when im tuck up sleeping inside.
I will use the buzzer type without a lcd display
The sensor will detect someone outside Then it will send a live to the buzzer and bleep i want to connect this wire to leds around the motorhome as proximity lights an come on at stage 1.
At the same time as someone gets closer the sensors will make a constant live to the buzzer but now i want to be able to have a voice siren to come on at stage 4
The alarm will switch on/off by a remote control key fob
The manual says reference detection
stage 1 150-100cm bi...bi...bi
stage 2 90-50cm bi..bi..bi
stage 3 40-30cm bi.bi.bi
stage 4 0-20cm bi............
So is it a case of somehow spliting these two voltages so i can set the leds lights flashing then the siren
The kit consists of 8 parking sensors link to a control box ,a buzzer wire come out of that box. The siren has its own live to a 12volt battery and two trigger wires live and negative.
I have tried wirring some leds to the buzzer wire and they flash at stage 1 my question is how many can i have without causing any problems is there a way to work this out.
I have also tried to wire the siern to the buzzer wire it works and comes on at constant but as you move away the stage 3 -1 interrupts it and turns it back on .
I think i need some sort of resistor to fix this but im complety new to electronics but keen to learn
Thankyou for any replies
