L
Leon Sorokin
http://rocky.digikey.com/WebLib/Measurement Specialties Inc/Web Data/LDTO Vibration Sensor.pdf
http://rocky.digikey.com/WebLib/Measurement Specialties Inc/Web Photos/0-1002794-0.jpg
i just got these LDT0 MSI piezo film tabs that i'm hoping to use in a design
i'm working on. the idea is to get an LED to flash on physical impact of the
entire PCB. but the LED is a Luxeon emitter, so it requires a good drive
current to flash it. i'm using the NDT451AN N-channel mosfet. it has a high
maximum VGSS voltage since the tab can generate up to 70V through a 90
degree deflection. but i looked at the graphs and i shouldnt ever see more
than 15V given that the impact would never deflect it more than 5mm. also i
needed it to trigger on fairly light impacts, so i chose the mosfet because
the typical gate threshold voltage is pretty low...1.6V, but i'm not sure
how much voltage is needed to completely saturate the gate. i connected the
piezo film tab between the gate and GND (rather the negative batt contact.)
i also have the gate grounded through a 169K resistor to discharge any
residual gate capacitance. i'm using a CR123A lithium battery for good
temperature range and flat discharge characteristics...so 3V for LED power.
how does the tab work?...does it generate +V with deflection in one
direction, and -V with deflection in the other? does that mean it will only
open the mosfet when deflected in one direction but not the other?? do i
need 2 tabs in opposite directions to generate the +V that the gate needs to
open it regardless of the deflection direction?
am i missing something critical that will surprise me?
if i understand anything, and i hope i do. this should work and not blow out
my mosfet? and will trigger fairly easily.
thanks,
Leon
thanks,
Leon
