Winfield Hill
Roy McCammon wrote...
Of course you've put us at a disadvantage, by not describing the
circuit you're considering. But using a 100mA depletion-mode FET
for GATE protection makes little sense, especially when a stated
alternate is a 1M gate resistor! The LND150 is a 1mA FET, with
Ron = 1k, so two in series can make a solid proper connection to
your power MOSFET's gate, yet still limit the 500V fault-voltage
gate current to 1mA, which can be easily dealt with by a variety
of means, without going beyond your FET's gate-voltage max spec.
See Supertex AN-D11 app note for the 1mA fault-limit concept.
- Win
whill_at_picovolt-dot-com
DN3535 is more like the impedance I want, but the sucker
leaks a whopping 1mA at 125C. That's easily measured; can't
believe its just a convenient spec because of the measurement
problem.
- Win
