"Jan Panteltje"
** Nonsense - DTV is all MP3 encoded.
There is no defined sampling rate.
First it is mp2 encoded, and second most is 48KHz sampled.
Here is an example:
mplayer -ao oss:/dev/dsp1 goldfinger.ts
MPlayer 1.0pre7try2-3.3.6 (C) 2000-2005 MPlayer Team
CPU: Advanced Micro Devices Duron Spitfire (Family: 6, Stepping: 1)
Detected cache-line size is 64 bytes
CPUflags: MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 0 SSE2: 0
Compiled for x86 CPU with extensions: MMX MMX2 3DNow 3DNowEx
Linux RTC init error in ioctl (rtc_irqp_set 1024): Inappropriate ioctl for device
Try adding "echo 1024 > /proc/sys/dev/rtc/max-user-freq" to your system startup scripts.
Playing goldfinger.ts.
TS file format detected.
DEMUX OPEN, AUDIO_ID: -1, VIDEO_ID: -1, SUBTITLE_ID: -1,
PROBING UP TO 2000000, PROG: 0
VIDEO MPEG2(pid=2342)AUDIO MPA(pid=2343) NO SUBS (yet)! PROGRAM N. 0
Opened TS demuxer, audio: 50(pid 2343), video: 10000002(pid 2342)...POS=10340
VIDEO: MPEG2 544x576 (aspect 3) 25.000 fps 10000.0 kbps (1250.0 kbyte/s)
Opening audio decoder: [mp3lib] MPEG layer-2, layer-3
AUDIO: 48000 Hz, 2 ch, s16le, 192.0 kbit/12.50% (ratio: 24000->192000)
Selected audio codec: [mp3] afm:mp3lib (mp3lib MPEG layer-2, layer-3)
vo: X11 running at 1440x900 with depth 24 and 32 bpp (":0.0" => local display)
Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
VDec: vo config request - 544 x 576 (preferred csp: Mpeg PES)
Could not find matching colorspace - retrying with -vf scale...
Opening video filter: [scale]
The selected video_out device is incompatible with this codec.
VDecoder init failed
Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b
Selected video codec: [mpeg12] vfm:libmpeg2 (MPEG-1 or 2 (libmpeg2))
Checking audio filter chain for 48000Hz/2ch/s16le -> 48000Hz/2ch/s16le...
AF_pre: 48000Hz/2ch/s16le
AO: [oss] 48000Hz 2ch s16le (2 bps)
Building audio filter chain for 48000Hz/2ch/s16le -> 48000Hz/2ch/s16le...
Starting playback...
VDec: vo config request - 544 x 576 (preferred csp: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.
VO: [xv] 544x576 => 1024x576 Planar YV12
You make too much noise, make yourself look ridiculous.
It sort of invalidates the rest of your remarks, as when you are so wrong
about this, how should I pay attention to the other stuff you scream?
