RichD
http://www.studiomaster.com/1984 - 1986.htm
"This was the amplifier pro sound companies were waiting for;
many buy up to 100 units. "
Did you use MOSFET on the output stage, and why?
RichD said:Did you use MOSFET on the output stage, and why?
Don Klipstein said:I occaisionally hear artifacts in 16 bit 44.1 KHz, in music.
It is easy to make a test signal turn up severe artifacts with 44.1 KHz
sample - see what happens with a sinewave at a higher audio frequency that
is several Hz off a frequency that the sample frequency is a multiple of.
Since I only occaisionally hear artifacts in music with 44.1 KHz 16 bit,
and when I do I usually find them minor, I would expect a sample rate
twice as high as that to be OK.
Jan said:I think it should be possible [I could] design powered speakers with a WiFi interface.
How would you synchronize the different channels?
Each speaker would have its own IP address, or perhaps its own port on one IP,
and from the [new] mixer only digital Ethernet to a wireless access point.
No bandwidth problem I think.
56 Mbits / second, should be enough for a few channels.
The real 802.11G throughput is 2.8MB/s at the best. An uncompressed
audio channel takes roughly 100KB/s.
The big problem with WiFi for audio is the synchronization between the
different WiFi units while maintaining the reasonable delay. This is
hard (if possible at all) to attain with the WiFi equipment.
AFAIK the solutions for audio via Ethernet (CobraNet and such) used the
special protocol stacks and were not fully compatible with the standard
networking stuff. In the general, Ethernet is not good as the network
for the multimedia; it was not designed for that purpose.
Jan said:On a sunny day (Sun, 21 Sep 2008 13:41:43 -0500) it happened Vladimir
<[email protected]>:
Yes, good point, timestamp would be one way, but that does not solve the delay.
the delay would be fatal in a live application.
Here is the idea: using the power frequency as the common timing
reference. In the local WiFi network, the ping time would be at the
order of 1ms, so all channels could be PLLed to the same half period of
the AC power without an ambiguity. With the sufficient amount of
buffering, that should allow streaming multiple synchronized channels.
Sooo simple... I bet somebody already got a patent on that.
Vladimir Vassilevsky
DSP and Mixed Signal Design Consultant
http://www.abvolt.com
Clever!
How about this: we give each speaker a GPS.
It will also send back its position, and the 'mixer' will
then calculate the optimum sound pattern for 5.1.
GPS also has a very precise clock.
With Quality of Service and no latency ?
Graham
JosephKK said:Vladimir said:Jan said:I think it should be possible [I could] design powered speakers with a WiFi interface.
Some time stamping and segment overlapping and a restricted RF
environment, plus NTP as needed for clock synchronization. Total
latency and latency variation are the primary issues. Maybe modified
bluetooth is a better idea (it really does support streams).
A bit more than that, the normal time 44.1 kHz 16 bits/sample CDA runs
somewhere around 1.5 Mbits/s. 48 kHz 24 bit audio (semi-pro and pro
level) takes a skosh more, about 1.15 Mbits/s per channel.
This is very true. If you want well time constrained transport, use
appropriate (usually telephone like or telephone) technology. If you
also want to ship video use SMPTE standards. The bitrates can be
daunting (SD-SDI {standard definition - serial digital interface
[both electrical and optical]} runs at 270 Mb/s) but the standards
guarantee interoperability.
Arny said:"Don Klipstein" wrote
Given the false claim that you've posted below, I somehow find that easy to
believe.
It's a common problem among vinylphiles and other digiphobes. They believe
some totally false, but possibly intuitively satisfying (to them) urban
myths about digital, and since they believe them, they hear them. One more
reason why only carefully bias-controlled listening tests can be trusted.
with 44.1 KHz sample - see what happens with a
sinewave at a higher audio frequency that is several
multiple of.
with 44.1 KHz 16 bit, and when I do I usually find
them minor, I would expect a sample rate twice as
So why do top-end studio use 24 bit 192 kHz like this from my old friends
and
colleagues at Prism Sound ?
Arny said:"Eeyore" wrote
But one with a pretty fair track record for hearing urban myths like the
crossover distortion that you claim exists in some power amplifiers.
Phil said:"Eeysore"
** Ignoratio elenchi .....
Yaawnnnnnnnn.....
http://en.wikipedia.org/wiki/Ignoratio_elenchi
Arny said:BECAUSE IT'S SO AUDIBLE IT STICKS OUT LIKE A SORE THUMB.
Your precious ABX testing guarantees only a 'lowest common denominator'
result.
Anyone that can't hear the distortion of QSC USA or MX series must have
severely
damaged hearing.
You were in the forces weren't you ? Explains it all. Hearing damage.
How do you KNOW that clock accuracy isn't a factor.
Depends on the phone. If I make a phone up out of a good vocal mic and some
studio monitors, it will be pretty good. These days really good electret
mics cost pennies, while good earphone elements are relatively small and
cheap compared to speakers. Most of the inherent losses in modern phones are
in the communications channel, which is wildly bandwidth-reduced. As
bandwidth becomes cheaper, there is a possibility that good-sounding
telephones will become commonplace.
Phil said:"Eeysore"
** Bollocks.
** Gobbledegook plus a massive non-sequitur.
** Shame how the rest of us do not have any of the defective examples YOU
claim YOU came across that lacked forward bias current in the output
devices.
Shame you were too lazy and dumb to give the bias trim pot a tweak.
Wanker.
** So what explains YOUR obvious brain damage then ?
Was it too much LSD or is it simply congenital ASD ???
If NASA can send broadcast quality video down from the shuttle or ISS,
howcome their audio still sounds like a fast food clown?
Everyplace but on test equipment, and in careful listening tests.
Let the record show that I have a number of QSC amps on hand to test, have
done so, and reported the results to Graham on Usenet. He has no such
resources at hand.
Horsefeathers.
