Hi all,
Bit of an odd one.
I have an aftermarket car ecu that has a 4 wire stepper motor attached to it.
Unfortunately, the ecu is current limiting to 1 amp.
The motor needs 1.85 amps (6.5 ohm motor, 12volts).
It therefore needs a bigger current supply (no position feedback needed).
Is anything available (make or otherwise) where the 4 inputs can be connected, and the higher current can be output?
thanks
Rod
Bit of an odd one.
thanks
Rod
