Monitor cable ID.
rodney
I have just bought some Sgi F180 flat panel displays
at auction and they are missing the video cables.
The specs refer to it as a
"15 pin D-sub connector / DVA connector"
Would the cognoscenti know if this cable
can be sourced from Dick Smith?
or if there is a generic name for this
"plug on both ends" cable?.
.....and if I can also ask why, with the option
to plug two computers into one monitor, why one
would want to do this?
Rodney.
F
Franc Zabkar
The user guide states that the monitor has "two signal ports (Dsub
port and DVI-I connections to 2 computers at a time".
http://techpubs.sgi.com/library/manuals/0000/860-0299-001/pdf/860-0299-001.pdf
http://techpubs.sgi.com/library/tpl/cgi-bin/summary.cgi?coll=hdwr&db=bks&docnumber=860-0299-001
Page 21 of the manual show the pinouts for the analogue and
digital/analog connectors.
From the specs page:
Type 18.1inch (45.97cm) Flat Panel Active matrix-TFT LCD
Anti-Glare coating
Viewable Size 18.1inch (45.97cm)
Viewing Angle (max.) 80° (Left / Right / Up / Down)
Pixel pitch 0.28 x 0.28mm
True color 16.7 million color
Horizontal Freq. 30kHz - 80kHz (Automatic)
Vertical Freq. 56Hz - 85Hz (Automatic)
Input form Separate, TTL, Positive/Negative
Composite, TTL, Positive/Negative
SOG (Sync On Green)
Digital
Signal input 15 pin D-Sub connector / DVI-I connector
Input Form Separate, RGB Analog, 0.7Vp-p/75ohm, Positive, Digital
Resolution Max VESA 1280 x 1024 @75Hz (Digital/Analog)
Recommend VESA 1280 x 1024 @60Hz (Digital/Analog)
- Franc Zabkar
Clifford Heath
It's what people used to do before KVM switches.
If you're working on a task that needs multiple
computers, you don't need the desk space for all
the monitors as well. A bit redundant in these
days of KVMs though, which save the keyboard and
mouse space as well.
rodney
Thanks Clifford.
rodney
Thanks Franc,
turned out to be just a "VGA cable" $10
up and running and the new 18"Sgi LCD
looks very smart indeed, thank you.
Good shopping at $90. :)
