Monitor cable IBM6549 (philips CM2500)
Russ Verdon
Have just restored EHT to a monitor salvaged from the kerb(dry joints on the
FETS in the HOT section).
As is often the case, the signal cable had been cut off.
I would appreciate it if someone with the schematic could tell me the pinout
for socket 1301on the neck board which is where the 15pin D signal cable
terminates. Specifically pins 8-13 of this socket, so I can correectly
connect another cable.
Regards
Russell
Russ Verdon
Have sorted the connections, found the uprocessor data and traced the
lines. Unfortunately the video is very smeared all over the screen. Also
with just the OSD running!!!
I
inti2
Luck !
If this monitor is similar to the G40... but those monitor usually have
pinouts writed near the connector...
this is the pinout of the cable on the board side (P501) (from up to down)
1) GND
2) R
3) GND
4) G
5) GND
6) B
7) V SYNC
8) H SYNC
9) O/R
10) SYN GND
11) SDA
12) SCL
Pinout of P502
1) CLP
2) CON
Pinout of P503
1) 12V
2) 100V
3) HT
4) G1
5) GND
Pinout of P505
1) V SYNC
2) H SYNC
3) O\R
4) SYN GMD
5) SCL
6) SDA
I.
