Hello.
I am new to this forum, and came here to ask the experts...
My issue -
input - momentary application of +12VDC to input wire should produce
output - (+) 12VDC on one output conductor and (-) on the other conductor for specified period of time (10-15 seconds, should be controllable)
input - momentary application of +12VDC to the same input wire should produce
output - (-) 12VDC on one output conductor and (+) 12 VDC on the other conductor fro specified period of time, reverse of the first momentary application, and should be time restricted, 10-15 seconds.
The purpose of this is to operate the power spindles - with one push of button, the spindles will spin in one direction for 10-15 seconds and then stop, with another push of the same button, the spindles will spin in opposite direction for 10-15 seconds and then stop.
I have tried SPDT, DPDT, timed relays, but I can't get it... I thought, if I can find a DP3T relay, i might accomplish something, but such a relay proved to be rather elusive.
Can anyone shed some light on this mystery?
thank you,
TerminatorX5
My issue -
thank you,
TerminatorX5
