Hello all, I'm Cris and I'm a woodworker that's looking to incorporate some electronics projects into my other hobby.
I'm totally new to this experience so I'm hoping to learn lots.
Could someone direct me to the appropriate forum for equipment questions?
Frankly I'm in the very start of this experience and I'm shopping for my kit. Specifically I'm uncertain what direction to take with regards to the Soldering iron specifically. Unfortunately I've got information overload - and was hoping for some kind people to help me choose from 4 options based on what I want to do.
So I think I've narrowed it down but I'm flip flopping on the following options:
The Weller WLC100 40W station - seems to be the basic station and I can get it for around $40.
A cheap knock off of the above weller - I've seen variations for around $20.
A basic Weller pencil type (the 40W with LEDs is avail locally at HD for under 20 right now).
and finally this variable temp Hakko FX600 Pencil type (which honestly I'm drawn to as it seems to be a good mix of both worlds).
Or is this overkill for what I'm attempting and should I just get a cheap $10 type and replace as needed?
Essentially, I'm hoping to modify various electronic to fit some wooden art pieces. eg, my router to fit into a decorative wall piece. As I'm seeing it, this should be relatively simple - desoldering some connectors and reconnecting them via a length of wire. That sort of thing.
As far as "new" creations, I have a few ideas (such as LED lighting for some pieces) but again, not working with microprocessors or anything like that.
Unfortunately, all my research has me flummoxed as the prevailing views seem to be - a good pencil soldering irons are good enough for light work vs all pencil soldering irons are the work of the devil vs. nothing but a good soldering station with temp control will do and everything else is wasting money. Then there's the power - "get the highest power", "if the power is too high it will burn your parts", "forget power, you need temp" etc.
So anyone who'd be willing to give a suggestion?
Thanks!
Thanks!
