In addition to inside I run my pc audio music stream to a sound system in my shop. I like to be able to just move one of the shops stereo system speakers outside when I am working there with a longer wire. The problem is that some of the music has mixing where the vocals or part of the music is not the best with one channel. So I am making a passive mixer for the shop setup. I would like to find an appropriate resistor value that won’t attenuate the signal any more than I have to. If this circuit does cause some input mixing that is not really a problem as I can disconnect the mixer when it is not needed so I won’t be diminishing my stereo effect in the house when I listen there. I have seen 10K recommended, but that was for general audio equipment and I don’t know if a pc output would need similar, I wouldn’t want to harm my pc sound circuits. What would anyone recommend for resistor values for this mixer? I can experiment if there is a range I should try, I would just like to have a good starting point if so. And since I am obviously driving two stereo systems (the main one will probably still be on, I don’t want to be flipping a switch back and forth) should I be using some type of impedance adjustment for that part of this? Thanks for any help.
Platforms
Content
