Microwave wiring for fan motor
This is a salvaged microwave fan motor.
I would like to use it as a standalone drying fan.
http://i1289.photobucket.com/albums/b516/drew77580/Microwave_Fan_zps8c7757d9.jpg
I feel that the red wire is hot, white is neutral, and green is ground wire.
I think the 2 gray wires on the very bottom can go to a switch.
What do you think ?
Thanks.
I Would expert that the white wire is neutral , the black wire is hot, and the green wire is ground. I can not tell from the photo if the white and black wire go to the same place, so could easily be wrong.
Dan
Jasen Betts
What do you think ?
Red is fused so looks like a good candidate for hot, green has a ring
terminal, typical of earth wires, white+black thus must be neutral
so that much sounds good.
It could be a tapped motor coil used as an autotransformer to power a low-voltage
(eg: 20V) gearmotor to drive the platter. In which case the greys are the low voltage
L
Lasse Langwadt Christensen
Den fredag den 29. november 2013 20.54.18 UTC+1 skrev Andy K:
What do you think ?
Thanks.
sounds right
The pcb is quite clear, red/white hot/neutral, through a LC filter then a fuse. y-capacitors to green ground
-Lasse
Andy K
sounds right
-Lasse
Thanks for all the responses.
I looked again at the motor itself.
I don't think the circuit board has nothing to do with the fan motor.
There are only two gray wires going to the motor.
Gray wires are 300V 22 AWG
Motor has sticker with this info
Oh Sung Oem 10DWX1-B07 120 V .3 amps MAX Z.P. M1104151
Does it look like I could hook up a cord to the grey wires temporarily to see if the motor works ?
Thanks,
Andy
On Saturday, November 30, 2013 10:39:25 AM UTC-5, Andy K wrote:
Yeah, it's just a crummy little impedance limited shaded pole motor, all it needs is voltage 120VAC. The little board is mounted there for convenience and is some power entry stuff like fuse and EMI filter for the whole oven.
Andy K
Thanks.
Sure noticed a ton of spam here in just one day.
Andy
Andy K
I want to cover the coil since it has 120 V going thru it.
Is it designed for air flow to go over it.
I could put a wood cover around it ?
Thanks.
Maynard A. Philbrook Jr.
Thanks.
If it to be cooled, I think it would be best to make a little sheet
metal box with perforated holes in it, so that it can breath..
You should be able to find that at a hardware store. The holes are
sized for pop rivets. with that you can fab a little cover and pop rivet
it together.
Look for "Perforated Sheet Metal"
Jamie
Andy K
[email protected] says...
it together.
Jamie
Thanks,
Andy
Andy K
it together.
Jamie
I think I will get one of those plastic project boxes with the rubber gaskets and drill some holes in it for ventilation.
Andy
