Tricky bit is getting the PIC to start from 1.2-1.5v in the first
place.
I wasn't sure that this would work since it looks suspiciously like a
perpetual motion machine. I think it has to transfer energy from the
battery into the series capacitor if it is to be sustainable.
But, as Jim would put it, how does it start?
I did wonder about the idea of making the on-off switch a dpdt with a
low leakage capacitor across the battery when the unit is switched
off, and in series when switched on. And then a boost converter to
keep it topped up during use. The PIC will start at >2v and keep
running once started a little lower than that.
There are clock outputs at 32kHZ(unbuffered), and buffered 8192Hz and
~50Hz available
I think I like the Joergs idea of the 74AUP1G14 low power Schmidt
trigger inverter best. Cheap and probably cheerful. There is something
appealing about getting low current stuff to run off a single 1.5v
cell efficiently.
The challenge here is to do it cheap, compact, with easily available
bits and a low parts count in a form that will work reliably for a
home constructor. There are quite a few hobby PIC circuits that would
benefit from a single 1.5v battery.
Regards,
Martin Brown
