Michael Robinson
I need a DC to DC boost circuit with an output defined not with respect to
ground, but with respect to the input, which is variable. Output about 15
volts above the input, over a wide range -- from less than a volt in, up to
15 or 16 volts in. But can be inefficient and only needs to put out a few
milliamps. I pasted an LTspice netlist of a possible solution.
R15 simulates a grain-of-wheat incandescent. For Q6, if the Zetex is hard
to find I might use a DSS416 or some such.
What's the consensus about the vulnerability of Q6 when Vin = 16 volts?
Version 4
SHEET 1 1388 680
WIRE 496 -160 -80 -160
WIRE 384 -144 352 -144
WIRE -80 -128 -80 -160
WIRE 352 -112 352 -144
WIRE 512 -112 352 -112
WIRE 560 -112 512 -112
WIRE 352 -80 352 -112
WIRE 448 -80 448 -144
WIRE 448 -80 416 -80
WIRE 512 -64 512 -112
WIRE -528 -16 -528 -48
WIRE -528 -16 -560 -16
WIRE -464 -16 -528 -16
WIRE -368 -16 -464 -16
WIRE -352 -16 -368 -16
WIRE -304 -16 -352 -16
WIRE -288 -16 -304 -16
WIRE -192 -16 -288 -16
WIRE -160 -16 -192 -16
WIRE 208 -16 -160 -16
WIRE 272 -16 208 -16
WIRE 288 -16 288 -112
WIRE 288 -16 272 -16
WIRE 304 -16 288 -16
WIRE 448 -16 448 -80
WIRE 448 -16 384 -16
WIRE -464 0 -464 -16
WIRE -192 0 -192 -16
WIRE 272 32 272 -16
WIRE 384 32 272 32
WIRE -368 48 -400 48
WIRE -256 48 -288 48
WIRE 272 48 272 32
WIRE 496 80 496 -160
WIRE 496 80 448 80
WIRE -464 96 -592 96
WIRE -448 96 -464 96
WIRE -384 96 -288 48
WIRE -352 96 -352 -16
WIRE -272 96 -368 48
WIRE -192 96 -208 96
WIRE -128 96 -192 96
WIRE 144 96 -128 96
WIRE 208 96 208 -16
WIRE -464 112 -464 96
WIRE -192 112 -192 96
WIRE -528 128 -528 -16
WIRE -304 128 -304 -16
WIRE -80 144 -80 -48
WIRE 16 144 -16 144
WIRE 272 144 272 128
WIRE 272 144 96 144
WIRE 352 144 352 -80
WIRE 352 144 336 144
WIRE 272 160 272 144
WIRE -464 208 -464 192
WIRE -416 208 -464 208
WIRE -352 208 -352 176
WIRE -192 208 -192 192
WIRE -192 208 -240 208
WIRE -160 208 -160 64
WIRE -160 208 -192 208
WIRE 208 208 208 176
WIRE 208 208 112 208
WIRE 208 224 208 208
WIRE -560 240 -560 64
WIRE -464 240 -464 208
WIRE -464 240 -560 240
WIRE -352 256 -304 208
WIRE -352 256 -400 256
WIRE -304 256 -352 208
WIRE -256 256 -304 256
WIRE -80 256 -80 144
WIRE -16 256 -80 256
WIRE 48 256 -16 256
WIRE 144 272 144 176
WIRE -592 320 -592 176
WIRE -528 320 -528 208
WIRE -528 320 -592 320
WIRE -464 320 -464 304
WIRE -464 320 -528 320
WIRE -384 320 -384 176
WIRE -384 320 -464 320
WIRE -352 320 -384 320
WIRE -304 320 -352 320
WIRE -272 320 -272 176
WIRE -272 320 -304 320
WIRE -192 320 -192 304
WIRE -192 320 -272 320
WIRE -128 320 -128 176
WIRE -128 320 -192 320
WIRE -80 320 -128 320
WIRE -16 320 -80 320
WIRE 112 320 112 304
WIRE 112 320 -16 320
WIRE 208 320 112 320
WIRE 272 320 272 256
WIRE 272 320 208 320
FLAG 560 -32 0
FLAG -528 -48 Vin
FLAG 512 -64 Vout
FLAG -80 320 0
SYMBOL npn -256 208 R0
SYMATTR InstName Q1
SYMATTR Value 2N2222
SYMBOL npn -400 208 M0
SYMATTR InstName Q2
SYMBOL pnp -400 96 R180
WINDOW 0 51 37 Left 2
WINDOW 3 31 60 Left 2
SYMATTR InstName Q3
SYMATTR Value 2N2907
SYMBOL pnp -256 96 M180
WINDOW 0 36 42 Left 2
WINDOW 3 -10 95 Left 2
SYMATTR InstName Q4
SYMBOL cap -240 192 R90
WINDOW 0 0 32 VBottom 2
WINDOW 3 32 32 VTop 2
SYMATTR InstName C1
SYMATTR Value 1n
SYMBOL cap -352 192 R90
SYMATTR InstName C2
SYMATTR Value 1n
SYMBOL cap -384 80 R90
SYMATTR InstName C3
SYMATTR Value 1n
SYMBOL cap -208 80 R90
WINDOW 3 8 14 VTop 2
SYMATTR InstName C4
SYMATTR Value 1n
SYMBOL res -320 112 R0
WINDOW 0 1 -2 Left 2
WINDOW 3 -13 62 Left 2
SYMATTR InstName R1
SYMATTR Value 47k
SYMBOL res -400 80 R0
WINDOW 0 0 40 Left 2
WINDOW 3 -5 70 Left 2
SYMATTR InstName R3
SYMATTR Value 47k
SYMBOL res -288 80 R0
WINDOW 0 1 42 Left 2
WINDOW 3 -2 72 Left 2
SYMATTR InstName R4
SYMATTR Value 4k7
SYMBOL voltage -528 112 R0
WINDOW 123 0 0 Left 2
WINDOW 39 0 0 Left 2
WINDOW 3 -42 -248 Left 2
WINDOW 0 -13 58 Left 2
SYMATTR Value PULSE(0 1 0 100n)
SYMATTR InstName V1
SYMBOL res -480 96 R0
WINDOW 0 3 55 Left 2
WINDOW 3 13 80 Left 2
SYMATTR InstName R5
SYMATTR Value 10
SYMBOL res -208 96 R0
WINDOW 0 -16 36 Left 2
WINDOW 3 -2 70 Left 2
SYMATTR InstName R6
SYMATTR Value 10
SYMBOL diode -288 320 R180
WINDOW 0 3 -13 Left 2
WINDOW 3 -84 -14 Left 2
SYMATTR InstName D1
SYMATTR Value 1N4148
SYMBOL diode -336 320 R180
WINDOW 0 88 -13 Left 2
WINDOW 3 -1 -12 Left 2
SYMATTR InstName D4
SYMBOL diode -272 48 R180
WINDOW 0 8 108 Left 2
WINDOW 3 -29 82 Left 2
SYMATTR InstName D2
SYMBOL diode -352 48 R180
WINDOW 0 31 45 Left 2
WINDOW 3 9 94 Left 2
SYMATTR InstName D3
SYMBOL res -368 80 R0
WINDOW 0 6 32 Left 2
WINDOW 3 9 71 Left 2
SYMATTR InstName R2
SYMATTR Value 4k7
SYMBOL res -608 80 R0
WINDOW 0 17 38 Left 2
WINDOW 3 2 88 Left 2
SYMATTR InstName R7
SYMATTR Value 4k7
SYMBOL res -576 -32 R0
WINDOW 0 -3 53 Left 2
WINDOW 3 -12 89 Left 2
SYMATTR InstName R8
SYMATTR Value 4k7
SYMBOL res -144 80 R0
WINDOW 0 15 38 Left 2
WINDOW 3 7 73 Left 2
SYMATTR InstName R9
SYMATTR Value 4k7
SYMBOL res -176 -32 R0
SYMATTR InstName R10
SYMATTR Value 4k7
SYMBOL npn 144 224 R0
SYMATTR InstName Q5
SYMBOL npn 208 160 R0
WINDOW 0 56 45 Left 2
SYMATTR InstName Q6
SYMATTR Value FZT849
SYMBOL ind 256 32 R0
WINDOW 3 64 53 Left 2
SYMATTR Value 100µ
SYMATTR InstName L1
SYMATTR SpiceLine Rser=.5
SYMBOL schottky 272 160 R270
WINDOW 0 32 32 VTop 2
WINDOW 3 0 32 VBottom 2
SYMATTR InstName D5
SYMATTR Value 1N5819
SYMATTR Description Diode
SYMATTR Type diode
SYMBOL pnp 384 80 M180
SYMATTR InstName Q8
SYMBOL zener 416 -96 R90
WINDOW 0 -4 32 VBottom 2
WINDOW 3 37 -14 VTop 2
SYMATTR InstName D6
SYMATTR Value BZX84C15L
SYMATTR Type diode
SYMBOL cap 352 -128 R90
SYMATTR InstName C6
SYMATTR Value 1µ
SYMBOL res 544 -128 R0
SYMATTR InstName R14
SYMATTR Value 4k7
SYMBOL res 192 80 R0
WINDOW 3 -254 -27 Left 2
WINDOW 0 -5 2 Left 2
SYMATTR Value R=100+sqrt(54000*V(Vin))
SYMATTR InstName R15
SYMBOL res 128 80 R0
WINDOW 0 -2 40 Left 2
WINDOW 3 -2 83 Left 2
SYMATTR InstName R16
SYMATTR Value 1k
SYMBOL res 400 -32 R90
WINDOW 0 9 81 VBottom 2
WINDOW 3 32 56 VTop 2
SYMATTR InstName R11
SYMATTR Value 1k
SYMBOL npn 48 208 R0
SYMATTR InstName Q7
SYMBOL res -96 -144 R0
SYMATTR InstName R12
SYMATTR Value 1k
SYMBOL res 112 128 R90
WINDOW 0 0 56 VBottom 2
SYMATTR InstName R13
SYMATTR Value 10k
SYMBOL cap -16 128 R90
SYMATTR InstName C7
SYMATTR Value 100p
SYMBOL diode 0 320 R180
WINDOW 0 24 64 Left 2
WINDOW 3 -17 25 Left 2
SYMATTR InstName D7
SYMBOL cap 448 -160 R90
WINDOW 0 27 65 VBottom 2
WINDOW 3 5 -6 VTop 2
SYMATTR InstName C5
SYMATTR Value 1n
TEXT -320 -136 Left 2 !.tran 0 5m 0
Version 4
SHEET 1 1388 680
WIRE 272 32 272 -16
WIRE 384 32 272 32
WIRE 272 48 272 32
WIRE 496 80 448 80
WIRE 144 96 -128 96
WIRE 208 96 208 -16
WIRE 16 144 -16 144
WIRE 272 144 96 144
WIRE 48 256 -16 256
FLAG 560 -32 0
FLAG -528 -48 Vin
FLAG 512 -64 Vout
FLAG -80 320 0
SYMATTR InstName Q1
SYMATTR InstName Q2
SYMATTR InstName Q3
SYMATTR InstName Q4
SYMATTR InstName C1
SYMATTR Value 1n
SYMATTR InstName C2
SYMATTR Value 1n
SYMATTR InstName C3
SYMATTR Value 1n
SYMATTR InstName C4
SYMATTR Value 1n
SYMATTR InstName R1
SYMATTR Value 47k
SYMATTR InstName R3
SYMATTR Value 47k
SYMATTR InstName R4
SYMATTR Value 4k7
SYMATTR InstName V1
SYMATTR InstName R5
SYMATTR Value 10
SYMATTR InstName R6
SYMATTR Value 10
SYMATTR InstName D1
SYMATTR InstName D4
SYMATTR InstName D2
SYMATTR InstName D3
SYMATTR InstName R2
SYMATTR Value 4k7
SYMATTR InstName R7
SYMATTR Value 4k7
SYMATTR InstName R8
SYMATTR Value 4k7
SYMATTR InstName R9
SYMATTR Value 4k7
SYMATTR Value 4k7
SYMATTR InstName Q5
SYMATTR InstName Q6
SYMATTR Value 100µ
SYMATTR InstName L1
SYMATTR InstName D5
SYMATTR Type diode
SYMATTR InstName Q8
SYMATTR InstName D6
SYMATTR Type diode
SYMATTR InstName C6
SYMATTR Value 1µ
SYMATTR Value 4k7
SYMATTR Value 1k
SYMATTR Value 1k
SYMATTR InstName Q7
SYMATTR Value 1k
SYMATTR Value 10k
SYMATTR InstName C7
SYMATTR Value 100p
SYMATTR InstName D7
SYMATTR InstName C5
SYMATTR Value 1n
