redbelly
I don't think so. We simply disagree. I think
what you posted is wrong, and apparently you
think what I posted is wrong.
or are you just one those that
Nope. I dislike the posts where the issue
is lost and ad hominum junk takes its place.
Probably not relevant whether it is auto ranging or not,
but the op did not say he has an Auto range meter.
He said he had an unbranded meter he got from Webtronics
and the only marking on it at all is "CCL " followed by
a 9 digit number. What he said makes the next paragraph
relevant.
I have what is probably the same meter, which I got
from them the same way he did - as a freebie when he
ordered a bunch of parts. The one in my hand right
now has CCL031017886 on it, which I assume is the serial
number. I have at least one more from them, also
received for free when I ordered a bunch of stuff.
What I think of your reason for texting that
way is not relevant.
On the Webtronics meter, assuming it is the same as
his, the reading has no decimal point. It shows
up as 566. When you use a second meter in parallel
with the diode testing meter and set the second
meter to read voltage, it reads .566, or very close
to it. My readings were 570 on the Webtronics, and
.575 volts on the second meter set to volts. Incidentally,
the second meter in diode test reads .572 with the
decimal point, and puts a V on the screen to indicate
it is displaying voltage.
Probably true. Considering the information value of the
reading, however, is not something that should be so
easily dismissed. On the one hand, we have information
that says, if you treat it as resistance, this diode has
566 ohms resistance. On the other hand, we have information
that says, if you treat it as voltage, this diode drops .566
volts. In both cases, the value is dependent on the current
in the circuit - an unknown. But .566 volt drop is much
closer to the actual drop that will appear when the diode is
in most circuits, than 566 ohms. For example, look at a 12
volt circuit where you need 100 mA through a diode. The math
says the damn thing would drop 56.6 volts if you use the 566
ohm figure, which is clearly impossible. A drop of .566 is a
lot closer to the truth.
Your disclaimer "you just got to be aware of the component
you're testing and not assume ohms" is right on target.
That wasn't my intention, but I don't see any reason or
need for you to apologize.
Ed
Ed,
A simple test to decide whether the meter is reading resistance or
voltage would be to run the diode test on a couple of resistors.
Something in the ballpark of 1k, but use two different values in case
one resistor gives identical numbers for voltage and resistance at
your particular test current.
Mark
