This is the whole circuit in KiCad. The MCU is 3.3V. I have connected the RESET pin to the MCU ground and 3.3V power supply.
Now thats bad that it cant be derived from the batteries on the left. I will have to put a separate battery and charge it from the batteries on the left?
EDIT:
This is the charger that I will use, it should work even when charging the batteries while they are connected in series.
Description of ABC-1220D FST:
Short-circuit Protection: Charger O / P cut-off automatically when short circuit. Overload Protection: Charger O / P current-limited automatically when overload. Reverse Polarity Protection: Charger O / P cut-off automatically when batteryreverse connection. Automatic multi-rate charging function: Equalizer Charge and Floating Charge. Parallel Operation Available: Parallel with Battery as DC Power Supply operation available. Unique LCD Display: Indicating both charger status and battery level. 3 LED Display: Red (Power On) , Green (Floating charge) and Yellow (Equalizer charge). Advanced SMD Technology: Reliable and Elegant.
Link:
https://www.battery-import.eu/p/fst-abc-1220d-12v-20a
EDIT:
Link:
