The Problem is that i'm trying to explain is that is there a such thing as a SERIES LOAD?
What does a series Load do? the voltage stays the same right? but it only changes the current? there is no voltage drop?
When do you measure voltage in series?
the load will ALWAYS be in series with the battery, yes when drawn out it may look like the battery is in parallel with the load but you can always reduce the load down to one value, and make one single loop.
The voltage drop on a battery is going to differ based on the load, if you have a 3V 10Ah battery and you put a 10 ohm resistor on it the voltage will drop more than if you had a 3V 40Ah battery, but if you have a 12V 10Ah battery the voltage will drop a lot more than the 3V, and a 12V 40Ah battery will drop less than the 12V 10Ah but more than either of the 3V batteries
Batteries have a 100% SOC voltage and a 0% SOC voltage, whenever you draw current from the battery you are going to lower the voltage, whether it be by 1 microvolt or 100 volts
The higher the resistance the smaller the drop because the current through the resistor will be less
The more current draw there is, the more the battery's voltage will drop
