I don't know yet. The package just arrived but I have a much more
pressing problem from an other client to deal with right now. Also a
chip that seems to not exactly do what I think it should. For that one
we have lab bench scope plots and the manufacturer is investigating.
This one simulates alright but chokes in real life.
I have a NCP3063 Buck on a Breadboard now. I'm using it to test
cross-regulation on a coupled inductor (+/- 5V out). It only
terminates on the falling edge of Ct.
See scope shot. Ct ramp and switch node same as Jorge's sim.
http://i42.tinypic.com/34nlitw.jpg
You can see the glitch on the Ct ramp when the switch changes states.
Joerg I used the MC33063 for a 15W DCM buck before, it was the first
SMPS I did on a PCB in college and it ran fine. Mind you it needed 3 x
1mF of output capacitance to get the ripple down to something
reasonable. The inductor was 12uH for 5V out at 3A; 15 to 20Vin,
60kHz. The peak current was a little over 6A ;-) using an external
P-Fet.
I think the only reason they don't show or recommend DCM is because
the already high and modulated ripple you get with Hysteretic type
converters is much worse in DCM particularly at higher power levels.
This isn't flattering for their IC so they just show CCM examples.
Just my thoughts.
Here is the output ripple 12Vin, 5V out, 0.4A. This is with a 220uH
inductor and a 330uF PSA POLYMER output cap. Doing a proper PCB and a
small LC filter (bead MLCC) would get rid of those HF oscillations
http://i41.tinypic.com/2mebbya.jpg
This is using the NCP3063 at 175kHz
