Abstract said:
yeah, I think the interleaved method is the same. By delaying the signal
slightly you are, in effect, picking up higher frequencies(relative to the
first)... the longer the delay the lower the frequencies you get. Because a
"low frequency" won't be able to change fast enough between two consecutive
samples as it would in 3. I'm not sure the math behind it but I think its
very similar to what I'm doing if one were able to represent it
mathematically(basicaly instead of shifting the frequency spectrums you are
shifting the clock... but they are equivilent mathematically)
There are two methods currently in use - one is old and the other is
new.
The old method is temporal (or time) interleaving in which multiple
digitizers are "interleaved".
This method is utilized to increase the effective sample rate of the
digitizer and often can
increase the memory length in a scope (since usually an individual
digitizer drives its own
memory). The amount of interleaving ranges from 160 digitizers running
at 125 Ms/s to
12 in Agilent scopes to 16 digitizers running at 1.25 Gs/s in Tek
Scopes. You will not find
individual digitizing elements running much above 1.5 Gs/s, so anything
faster is time
interleaved (this is for real-time digitizers - don't get confused with
equivalent time or sampling
scopes which behave completely differently). While interleaving seems
easy, it is very
difficult in that that the frequency response of each digitizer must be
matched precisely.
The new method is one which shifts frequencies. This method has the
added advantage
of increasing bandwidth. The following white paper explains this for
the layman.
http://www.lecroy.com/tm/Library/WhitePapers/PDF/DBI_Explained.pdf
The frequency shifting method has been used successfully in the
development
of an 11 GHz, 40 Gs/s scope (the LeCroy SDA 11000) and an 18 GHz, 60
Gs/s
scope (the LeCroy SDA 18000) which is the fastest real-time waveform
digitizer
on the planet.
There are many issues with the development of such an instrument. No
one would
attempt such a design without the DSP capability to recover and "fix"
the waveform
after running the gauntlet of the microwave circuitry required to
separate, downconvert
and acquire the waveforms. LeCroy has this expertise and is the world
expert in
waveform processing and analysis.
The phase is affected by the local oscillator used for the mixing
action and the phase of the
local oscillator must be known or recovered in order to accomplish the
desired result -
something you might not have considered. Additionally, the sharp
filters utilized create
quite a bit of phase distortion at the band edges that must be
corrected.
search the patent and publication database at
www.uspto.gov for more
details.
P.S. Don't believe all of the Tek stories - they'll tell you they
invented everything - especially
if you're in the market for a scope
Pete Pupalaikis
www.LeCroy.com
