Joerg
Simon said:Tom said:On Sep 11, 11:15 am, Joerg <[email protected]>
wrote:Tom Bruhns wrote:
how much you can do. At a 45MHz center frequency, without going
really overboard with the LC filter, you probably will end up with a
3dB bandwidth at least a couple MHz wide. To do much better while
keeping the filter loss low requires coils with high Q, which get
physically large.That's where the old concept of the Q-multiplier comes in. After that it
only boils down to how good you are able to control the CF of a resonant
circuit up front. But shhht, don't tell anyone. The younger lads out
there don't have the foggiest idea what that is.Ouch! Not around my designs, thank you. :-([For the uninitiated: just stay away from them.]
What made you gun-shy here? Got hurt by them? Nowadays you can create
nice gain controlled amps and in most of my cases this is under full
computer-control. That was way different when I started as a teenage
hobbyist where the price tag of an Apple II would make you cringe. Now
you can buy a uC for a buck.
Baaackk iiinnnn theeee oolldddd ddaaaaysss wwhhhhheenn IIII
wwwwwwwaaaaaaaaasssssss yyoouuuunnnggg, I had the bright idea to add
negative resistance to improve the Q of an otherwise passive bandpass
circuit, since the coil was limiting the performance due to its Q. An
experienced engineer told me not to bother trying for commercial grade
equipment that had to operate across a wide temperature range. I never
revisited it.
So you've had luck with this technique at RF? Seems more a ham/garage
thing to me.
Yes, I did. Can't release much in details. Suffice it to say that you
need to continually test where you are on the "real" feedback slope.
This has become tremendously easier these days since you can get a uC
for a Dollar and neat serial ADCs for not much more. Temperature is what
makes it drift and it is slow enough that you can get away with a loop
BW in the tens of Hertz. We've even done something similar in the THz
domain but that one I can't talk about at all.
Don't start with a lousy inductor. A Q-multiplier isn't the tool to
paper over a bad LC design. Also, at some point microphonics will become
an issue and you don't really want to be regulating those out.
