RST Engineering \(jw\)
Excuse me, you wanna rethink that answer before I give you the sophomore
engineering lecture on dB?
Jim
Jim
That would be just fine, too, 'cept that in my quick look, it
looked like the 4:1 turns ratio from MiniCircuits was much
cheaper than any suitable 5:1 in their catalog.
M/A-com has some similar small transformers and may have
something in a 5:1 turns ratio that would be appropriate.
I'm not sure how sensitive these particular filters are to load
impedance. With many filters, if you're not trying for the
absolute best conformance to the specified filter shape, a modest
mismatch from the recommended load and source impedances doesn't
really matter that much. It's one of those "YMMV" things--test
to be sure you get what you want.
Tony said:Thanks Tom. As you know rf is not my bag so I'm an
interested lurker on these threads, trying to follow
the sums..... and where the sums produce something
that may not be practical to implement. That was the
reason for the question.
A 1:4 transformer could be used as a 1+4 auto of course.
AFAIR from the data sheet, that filter is about 75KHz
bandwidth, but they also specify a guaranteed attenuation
out at +/- 1MHz from the centre frequency. So presumably
the source/load impedance has to be somewhere near the
req'd 1200//1.8pF over that range.
It's like all the other crystal parameters, that impedance
derives from the motional parameters near resonance and in most
applications designers use bandpass impedance matching to avoid
exciting spurious responses and non-linear mixing in the crystal.
I take that to mean that the 1200//1.8pF need
only be maintained for not much more than the
75KHz passband. Thanks Fred.
Jim
Tom said:Let's see here...if I didn't miss anything, to begin with, the loss
will be quite a bit more than 6dB. The filter load/source is supposed
to be 1200 ohms in parallel with 1.8pF. I believe Joerg left off the
1.8pF in his suggestion of a series 1150 ohm resistor. Then the
output is to be terminated in net 1200 ohms and 1.8pF. For the
purpose of calculation, assume in the passband that the filter looks
like a simple short circuit. So the 50 ohm source now is delivering
power to 2400 ohms in parallel with 0.9pF. How does the power
delivered to the output 1200 ohms || 1.8pF compare with the power the
50 ohm source could deliver to a 50 ohm load? THAT's how much you are
giving up. And a bonus question: what other problems are caused by
not terminating the 50 ohm source in 50 ohms, and how much MORE loss
is there if you do add a resistor there to yield a net 50 ohm load?
(Hint: double-balanced mixers generally perform much worse with
respect to distortion products if they are not properly terminated...)
RST said:That wasn't the point, Tom. You are absolutely correct, the total loss will
be a great deal more than 6 dB; my ORIGINAL point said "...right off the
crack of the bat..." with resistive matching. If I had carried it through
to a logical conclusion it would have been much worse.
No, my point to the person who said that if you lose 6 dB in voltage you
have lost 3 dB in power was the ultimate decibel freshman student blunder.
I'm sure you will agree that if you lose 6 dB, you lose 6 dB measured in
voltage (2:1) or power (4:1).
Tom said:A bit more than that, actually, Tony. It's good to not hit a crystal
filter with out-of-band signals that are too high in amplitude,
because crystal filters (a) have spurious responses (should be pretty
low if it's a good design, and well implemented), and (b) are not
strictly linear devices and thus will allow mixing of two out-of-band
signals to produce an in-band signal. Crystal filters are generally
pretty low distortion, but people going for the ultimate in receiver
performance end up paying a lot of attention to their crystal
filters. So anyway, it helps to have some filtering in front of the
filter, to avoid those problems, though there's an obvious limit to
how much you can do. At a 45MHz center frequency, without going
really overboard with the LC filter, you probably will end up with a
3dB bandwidth at least a couple MHz wide. To do much better while
keeping the filter loss low requires coils with high Q, which get
physically large.
On the other hand, in a lot of applications, the crystal filter
distortion and spurious responses are low enough that relatively
broadband coupling is not a problem. You need to look at the whole
system to decide what's appropriate.
physically large.
Cheers,
Tom
RST said:No, my point to the person who said that if you lose 6 dB in voltage you
Tom Bruhns wrote: ....
That's where the old concept of the Q-multiplier comes in. After that it
only boils down to how good you are able to control the CF of a resonant
circuit up front. But shhht, don't tell anyone. The younger lads out
there don't have the foggiest idea what that is.
Ouch! Not around my designs, thank you. :-(
[For the uninitiated: just stay away from them.]
Tom said:On Sep 11, 11:15 am, Joerg <[email protected]>
wrote:Ouch! Not around my designs, thank you. :-([For the uninitiated: just stay away from them.]
What made you gun-shy here? Got hurt by them? Nowadays you can create
nice gain controlled amps and in most of my cases this is under full
computer-control. That was way different when I started as a teenage
hobbyist where the price tag of an Apple II would make you cringe. Now
you can buy a uC for a buck.
Fred Bloggs said:Yeah, well no person said that. I did say that half-power is 3dB. You have
a problem with that?
place where loss adds directly to noise figure."
Tom said:Tom said:On Sep 11, 11:15 am, Joerg <[email protected]>
physically large.That's where the old concept of the Q-multiplier comes in. After that it
there don't have the foggiest idea what that is.Ouch! Not around my designs, thank you. :-([For the uninitiated: just stay away from them.]
Prove to me you can add one and maintain +55dBm IIP3 and I might think
about it. ...
... Well, heck, prove to me that you even NEED it in front of a
GOOD crystal filter, too.
about it. Well, heck, prove to me that you even NEED it in front of a
Cheers,
Tom
