Todd L. Peters
Hello,
Is anyone able to help me with the design of a Marx Generator? I require a
fairly substantial unit to power a laboratory apparatus but am slightly put
off by the cost of commerical units, to say the least..
I wish to build a unit with a variable discharge voltage and electronically
triggered discharge. I understand that the discharge voltage can be varied
by adjusting the spark gap at the trigger. Could the same thing be achieved
by monitoring the potential difference and triggering the unit when the
desired voltage is achieved during charging?
My questions involve formula for the selection of capacitors and resistors,
and what overall needs to go into the selection of them as far as ratings.
I would also need to build a charging system, which seems like the complex
part.
Commercial units that I have seen are immersed in oil. Is this for safety
reasons? What are the advantages of doing this? How is the unit discharged
when it is submerged in oil (I assume that spark gaps can no longer be
used). It would seem to me that corona effects would be much less of an
issue in oil.
I am interested in building a SAFE unit that will allow me to perform
repeated, reproducible, calibrated discharges in a laboratory environment.
Fabrication of the unit in a quality manner is not a problem, it is the
design of the unit to be accurate and safe.
Any information is appreciated.
Sincerely,
Todd L. Peters
part.
issue in oil.
Sincerely,
Todd L. Peters
