Adrian Jansen
If you conserve energy, then you must haveJim said:Depends on the definition of "depends"
"Charge" IS conserved. So if you transfer Q from C1 to C2 >>>
C1*V1 == C2*V2
...Jim Thompson
C1*V1^2 = C2*V2^2
C1*V1 == C2*V2
...Jim Thompson
Your "point" is, as usual, vagueness and subterfuge... and BS.
For amusement, newbies are invited to MATHEMATICALLY analyze this
simple case...
Two equal value capacitors (C), one charged to Vo, the other uncharged
(zero volts).
Connect together with a switch, start with a finite resistance value,
analyze; then reduce the resistance, re-analyze; continue this
analysis, approaching zero in the limit.
Then scratch your head in surprise... where did the energy go ?![]()
C1*V1^2 = C2*V2^2
I CAN do the math! Can others here? Why do you think I was dumping
on Larkin?
First Law of Thermodynamics: You always lose
...Jim Thompson
Thanks Fred,
I would have thought that as the Capacitor closes (eg C increases ) the
Voltage decreases, but net Charge remains the same..
Sort of like going from High Impedance to Low Impedance. It's trading
Voltage for Current, which is what we want.
I agree the attraction between the plates will drive the Cap like a
motor. Is this good or bad?
C1*V1^2 = C2*V2^2
John said:Right. If you dump all the energy from one charged cap intoAdrian said:Jim Thompson wrote: [snip]
C1*V1^2 = C2*V2^2
another, discharged, cap of a different value, and do it
efficiently, charge is not conserved.
John says, "...charge is not conserved."
Newbies are invited to Google on "conservation of charge".
(AND run the math problem I previously posted.)
John is so full of it I'd bet his eyes are brown ;-)
Unfortunately, Adrian Jansen mis-states the results as well :-(
Billiard balls roll, which means that at the instant of contact there
is a transverse scraping, like a clutch engaging, which wastes more
energy than a classic elastic sphere conservation-of-momentum physics
problem. The angular momentum transfer is a lot like transferring
charge between two capacitors by connecting them with a resistor, but
worse because of the felt.
Air hockey is closer to classic elastic collision.
John
So, is the question then:We've gone from "dumping" to running a switcher.
Got one at 100%? Power-Out == Power-In ??
...Jim Thompson
Winfield said:Jim Thompson wrote...John Larkin wrote:
Adrian Jansen wrote:
Jim Thompson wrote:
[snip]
"Charge" IS conserved. So if you transfer Q from C1 to C2 >>>If you conserve energy, then you must have
C1*V1^2 = C2*V2^2Right. If you dump all the energy from one charged cap into
I haven't been following this thread, but I have a comment.
The operative phrase must be, "and do it efficiently."
This is easy to do, with a dc-dc converter for example, or a
mosfet switch and an inductor. In these cases it's easy to
manipulate E1 and E2, C1*V1^2 = C2*V2^2. Forget about charge.
"Forget about charge."???
I guess it depends on your definition of "depends" :-(
On the other hand, energy is always conserved.
John
If you are around to observe and tell about it.
Well, Heaven help us, Larkin could "slosh" forever![]()
Cite?
It helps to understand ideal circuits before you consider real
circuits. The ideals are the limiting cases. You CAN transfer charge
between equal value caps without loss of charge, and you can more
generally transfer energy between caps without loss; just use an
inductor.
Some of TI's buck-boost configurations look a bit like what you
describe:
http://focus.ti.com/lit/ds/symlink/tps63020.pdf
kevin
If you like air hockey pucks better do it for them instead. You can evenBilliard balls roll, which means that at the instant of contact there
John
Jim Thompson wrote:
[snip]
Exactly. To say "Charge is always conserved" is absurd. It is
conserved in some situations, not in others. The context must be
stated exactly.
Charge two identical caps to the same voltage, then connect them in
parallel, but with polarities flipped. ALL the charge vanishes.
John
assume any spins you want including no spins. Please continue.
