A 2 Amp transistor will work fine... depending on the length of the LED strip you want to use. I can't say for certain.okay so a 2 amp transistor would work? a tip 112 would handle it fine?
also, when buying capacitors, does it matter what voltage they operate at? like 16, 35, 50? cheers
Do you want to power the whole roll? Or only a portion?
As far as the capacitor ratings, the most important part is the uF value. Secondly, you choose the voltage it is 'capable' of.
So if you are using it in a circuit where it will see 5V, grab one that is rated for higher and you'll be fine.
