I have a self operating chicken coop door out in the yard. It opens and closes based on light, and works fine. I have the 12v wall wart power supply in the house on my workbench, with about 50' of #18 wires going out there (+12v & Grd).
Along with the power supply I have a monitoring display with a fuse, an on/off switch, a digital volt meter, a digital am meter, and a Fuse lamp. I would like the fuse lamp to light up when there is high current draw in the coop so I will notice it. I said the system works fine, and it does, except when I try to incorporate the Fuse Lamp. I tested the FL with my bench DC power supply, and it drops 4v and passes 350mA, and lights up nicely (I guess that makes 11 ohms resistance). With the 4v Fuse Lamp voltage drop, the remaining 8v is in-sufficient to operate the door motor.
I tried numerous series and parallel arrangements, with no luck. I also tried figuring out how to incorporate a zener diode. The lamp was always on.
So I Youtubed some transistor lessons, and tried to make it work that way. Nope. (I modeled it in TINA). So I have decided to ask for help. HELP ! I have attached an image which shows the circuit I came up with. The top one has 47 mA draw in the chicken coop and a 47mA current thru the fuse lamp - it is off, great.
The lower diagram shows the coop drawing 329mA, and the fuse lamp still around 47mA - not lit up.
I just can't figure out how to make the base current more sensitive to the main line current. Image attached
