This is an example of a common emitter voltage amplifier. It might be one of
the easiest stages to design. Normaly, I would start off by knowing what I
need for the stage, for example I need a voltage gain of 20, an input
impedance of 10K, Z out of ?? etc ----
<snip>
I take your point about selecting a BJT for the desired Iq.
After that, my next consideration is in setting the
collector's average Vc, given an Iq. I want to leave 1V for
the dc bias of Ve to stay well above (kT/q)/Iq. And since I
want to keep the BJT unsaturated I also preserve 1V for Vce.
In your 15V rail case, that leaves me 13V for Vc to wander
around in. Half of 13V is 6.5V. Add back in the 2V I'm
saving, and that sets Vc at Iq as 8.5V.
I set the collector resistor to (Vbat-Vc)/Iq. I get 6.5k for
that. What the heck, make it 6.8k. Iq is now 956uA. Oh,
well.
The emitter resistor is easily set to 1/956uA or slightly
more than 1k. Call it 1k. This means Ve will be about
0.956V. Livable.
On the biasing, I start by assuming that about Iq/5 should
flow in the divider. Say 200uA? (You started out thinking
in terms of the thevenin, instead, and a different rule of
thumb for it. I just use the 1/5th rule.)
Assume Vbe about 0.7V, the base should be at 956mV + 700mV or
about 1.66V. Maybe a little less, maybe a little more.
Assume less, hope for a little more. So 1.6V/200uA is 8k and
(15V-1.6V)/200uA is 67k. Let's go for gusto and pick 68k and
8.2k.
Now, I want a gain of 10? I can either bypass the emitter
resistor with another R+C in series across it or I can divide
up the emitter resistor into two pieces in series and bypass
just one of them, leaving the other one active at AC. With
the collector resistor of 6.8k, a gain of 10 would suggest an
AC resistance of 680 ohms in the emitter. To get that from
the 1k DC for the emitter, we put that 680 in series with a
330 and bypass the 330 with a cap sized appropriately for the
lowest frequency of interest to be close to a 'dead short.'
AC impedance is going to be about the thevenin of the base
pair of resistors divided by (1+5/beta) -- the 5 comes from
my 1/5th factor I earlier chose. If I keep that very much
smaller than the beta, it doesn't affect things much... as
you say. The thevenin of 68k and 8.2k is about 7.3k. With a
beta of 100, for example, this drops to about 6950 ohms.
I'll stop at this point and plug it into LTspice with a
2N2222 model they include (who knows if it is 'good'?)
Adding a signal source through a cap to base, I get a gain of
9.6, an average base voltage of 1.58V, average Iq of 921uA,
and a center Vc of 8.74V. AC impedance is computed as 6961
Ohms in LTspice. Pretty close, really.
Now... to the breadboard for a quick DC check. OnSemi
PN2222A just taken from an ammo pack. Collector resistor of
6.800k, emitter resistor 1.008k, base to ground resistor of
8.360k, base to V+ of 69.53k. Measures (rounded):
Vbat = 15.1
Vb = 1.59
Ve = 0.95
Vc = 8.73
I haven't hooked up the signal generator, yet. I'll need to
move upstairs to do that and get the scope fired up. But
that's a quick check of reality.
Now, plugging the Vbat back into LTspice and the real values
of the resistors I used, I get this from LTspice (rounded.)
Vb = 1.59
Ve = 0.94
Vc = 8.8
Which is ... pretty close. (The OnSemi PDF for the part
doesn't include a spice model for it and a search on their
site only comes up with the MMBT2222, so I'm using the
LTspice model for now.)
Jon
