Jon Kirwan
Hehe. Sure.
Sorry... I didn't stick in the link. Because it isn't set
up well, right now. Let me fix that and post it up and then
I will add the link.
Jon
Hehe. Sure.
Have you read Randy Slone's power amplifier book? This stuff really
isn't rocket science. Nor is AB. ;-)
I haven't. It's not rocket science. But it is interesting
at my level.
<http://www.amazon.com/High-Power-Audio-Amplifier-Construction-Manual/
dp/0071599258/ref=dp_ob_title_bk>
I'll look, but the title appears more on the contruction
side. I am using this to educate myself a little better.
The black art is all in assembly, protection circuitry, and making
sure it starts up cleanly. [Most engineers never look at start up, so
you get designs that thump when you power them. I have lots of gear
with power-on thumps.]
I recall reading of a recommendation suggesting that all
electronic devices use less than 1W when on, but not
performing their intended application. This would also seem
to require a little added effort to achieve, as well. But I
take your point.
I'd pick one of his MOS designs. Bipolar designs often have good
intentions, but ring like a bell. MOS is mushy, but predictably mushy.
I'm still learning about BJTs. In fact, that's what this is
about for me. MOS later. ICs later. BJTs now.
Jon
There is plenty of circuit design in the book. It is the assembly
stuff (ground loops, thermal tracking, etc.) that people screw up.
Anyway, I'd wait for the new edition.
You realize you can just string diodes. Nobody says you have to VBE
multiply. It's just one of many biasing techinques.
<snip>
Less words and real schematics would get you more readers. [The only
thing worse than ascii equations are ascii schematics.]
ASCII is what I'll post. It's the only way to get them
archived or properly posted to a text newsgroup. I no longer
have access to the binary for schematics, sadly. If I lose
some people because they cannot manage fixed-spaced fonts, I
guess I lose them. I could place links up on my domain, I
suppose. But in this case, the schematics are really very
basic and not overly burdensome in ASCII. Besides, Win Hill
posted some really nice examples here, before. Folks seemed
to live with that. Not sure why you are picking on me, here.
In any event, just google improved vbe multiplier. I've seen all sorts
of circuits published to get lower impedance at the nodes.
Okay. I'll do that if folks here aren't interested at all in
talking about it.
Jon
There are all sorts of free places to post images. Imageshack comes to
mind. I just lose interest if I have to look at ascii circuits.
No hurry. Thanks, Bob Monsen
: asc version 1.2.1, (library C:\TOOLS\BIN\ASC.SYM found)
: This program converts LTSpice schematics into ASCII schematic output (or
: files.) If you specify no files at all, it accepts the LTSpice schematic
: from its standard input device. If you specify exactly one file, it dis-
: plays the ASCII schematic output to the standard output device. If you
: specify more than one file, it then generates .TXT files otherwise having
: the same name as the specified schematics.
: These options are supported:
: +h requests this help message, -h disables it.
: +r enables rectangle drawing, -r disables it (default is -r)
: +c enables clipboard copying, -c disables it (default is -c)
: +c<char> enables clipboard copying and prepends <char> to each line
: Usage: asc <options> <filename> [<filename>]...
George Herold said:Say can you make a push-pull stage run class A? (Or is that just a
silly idea?)
You really can't convey much more than a "basics" circuit with ASCII.
Post links or use LTspice listings... everyone seems to have that ;-)
Have a look -
http://www.xmission.com/~bmge/Feedback.htm
On Wed, 10 Feb 2010 15:37:00 -0800, Jon Kirwan
[snip]I still _get_ the idea of NFB!! So I don't mean to argue
against that! I just went somewhere else with that page.
Jon
First rule of "NFB": Make it as good as you possibly can without NFB,
_then_ apply NFB ;-)
But it's sort of a trick and a lie... you use _local_ feedback to make
the individual pieces as linear as you can, then add overall _global_
feedback.
...Jim Thompson
"George Herold"
You can, but it stops being class A for large signal swings or low load
impedances.
Jon Kirwan wrote in message ...On Wed, 10 Feb 2010 15:37:00 -0800, Jon Kirwan
[snip]
Jon
feedback.
...Jim Thompson
Now _this_ is what I wanted to hear.
Many seem to just tell me "use global NFB to fix things"
almost, it seems, to simply stop me from bothering to
struggle at all or even care about understanding things.
Maybe it is just because it _takes work_ to actually engage a
quantitative discussion and the lazy way out is to just hand
wave and tell me to "move on by."
But it was my sense at the outset, and it is my motivation
for starting this thread as well, to do exactly what you are
talking about here. I'm so glad to see it said. "Make it as
good as you can without NFB, then apply NFB." Yes!
For example, the Sziklai pair is really a BJT wrapped with a
local NFB using the other BJT for that purpose. Nice.
I couldn't state it this clearly because I'm just learning
things. But what you said is what my instincts tell me,
despite attempts to say "move on, there's nothing to see
here."
Jon
Jim hit the nail right on the head, make it linear as possible with local
feedback first. Add global later if it applies -
I put that page together
as a quick reponse so that you might see for
yourself what I mean by feedback being used to stabilize things. It is far
from an in depth analysis and there very well could be something desperately
wrong with the circuit, but it does reduce the drift to 1/4 of the circuit
without feedback and that is the point of my post.
Again , try to find the book, it is the best advice I can give.
@My-Web-Site.com> wrote:On Wed, 10 Feb 2010 15:37:00 -0800, Jon Kirwan
[snip]
_then_ apply NFB ;-)But it's sort of a trick and a lie... you use _local_ feedback to make
feedback....Jim ThompsonNow _this_ is what I wanted to hear.Many seem to just tell me "use global NFB to fix things"
struggle at all or even care about understanding things.Maybe it is just because it _takes work_ to actually engage a
wave and tell me to "move on by."But it was my sense at the outset, and it is my motivation
good as you can without NFB, then apply NFB." Yes!For example, the Sziklai pair is really a BJT wrapped with a
local NFB using the other BJT for that purpose. Nice.I couldn't state it this clearly because I'm just learning
here."Jon
Thanks. Now why do I instead find myself sometimes having to
actually _argue_ about understanding building blocks well?
Why is the answer so often, "throw gobs of global NFB at it?"
I wonder if the availability of all-too-perfect A_ol = 1E15
opamps (not really, but what's the difference?) is part of
the problem, here. Maybe it's making things too easy.
Ah. That was you? Thanks for the effort, then!!
I think I already understood the majestic power of global
NFB. It's so important, I am sure, that if NFB didn't _also_
wrap the output stage itself, the results would be indeed
very lousy no matter how good the earlier part of it turned
out to be. So it is not an option.
I did learne the basic gain/feedback equation years ago:
Vout/Vin=A/(1+A*B), with B being the feedback and A the open
loop gain. With gobs of A available in these all-too-perfect
opamps these days, the whole thing drops back to 1/B 'real
fast.' Which is nice because then just set B and get handed
a fixed gain on the so-called silver platter.
I have to still believe, as broadly ignorant as I indeed am
about these things, that crafted design with localized NFB
remains useful even in the case of audio amplifiers. That
doesn't mean the power of global NFB isn't of the overarching
importance that it is. There is no option there. But there
remains more to life than merely that, too. Local NFB seems
to remain important to me. And it was nice that Jim took a
moment to confirm that impression, when so few had done so
beforehand.
... You also noticed that I took the web page in a totally
different direction?
Speaking of which, what spice model did you use for that
2N3904? Can you post it? I'd like to stick it into LTspice
and see why I got different results. Since my calculations
didn't depend too highly on wrong estimates of beta and since
kT/q doesn't care about the BJT, I'm curious about exploring
it a little more.
Thanks,
Jon- Hide quoted text -
- Show quoted text -
Hi Jon, I'm loving your threads...
(did any one ever tell you your kinda long winded?)
I wanted to take exception to your opamp statement,
"I wonder if the availability of all-too-perfect A_ol = 1E15
the problem, here. Maybe it's making things too easy. "
As the frequency of interest approachs the GBP the gain goes to 1 and
things get intresting...
George H.
** Push-pull class A is the MOST COMMON method use in tube and transistor
audio power amplifiers.
With transistor amps, it is only necessary to set to standing bias current
to a high value like an amp or two.
** No need for either thing to happen.
One picks the load to suit the amplifier and the peak ( class A) current
is
double the bias setting current.
Eg:
With a bias of 2 amps, peak load current is 4amps which allows +/-32 volts
into 8 ohms.
Class A power is then 64 watts rms.
The DC rails need to be about +/- 35 volts and the supply current a steady
2
amps.
Tubes can't do push-pull because "it's hard to get positrons from the
filament" to parapharse what I read.
I'm perhaps more of a novice than you...
but I find opamp circuits complicated enough....
And tend to stick transistors
only on the edges of things. (Mostly on the output side... on the
input you have to 'know more' than the guys who designed the opamp..
hard to do for a novice.)
I guess if I was designing an audio amp I'd figure on an opamp driving
some sort of FET output stage. The question of how to bias the output
stage is interesting. And also of how all the NFB works.
This is the model that came with circuitmaker - -
*2N3904
*Si 310mW 40V 200mA 300MHz pkg:TO-92B 1,2,3
.MODEL 2N3904 NPN(IS=1.4E-14 BF=300 VAF=100 IKF=0.025 ISE=3E-13
+ BR=7.5 RC=2.4 CJE=4.5E-12 TF=4E-10 CJC=3.5E-12 TR=2.1E-8 XTB=1.5
KF=9E-16 )
I don't use LT so I'm not sure if the commented (*) text needs to be
removed.
These spice model files might be of interest but possibly obsolete - google
for them
OnSemiconductorAllModels.zip
OnSemiconductorDiscreteModels.zip
OnSemiconductorIntegratedFunctionsModels.zip
"Tim Williams"
One picks the load to suit the amplifier and the peak ( class A) current is
Eg:
into 8 ohms.
The DC rails need to be about +/- 35 volts and the supply current a steady 2
amps.
..... Phil
Jim Thompson said:And a 2.5V "dead-band", but it _is_ precisely known, and temperature
stable. Interesting thought if you have high enough power supplies.
Go with the OnSemi model.
...Jim Thompson
<snip>
In other words, although OnSemi has a realistic model for
their own parts, which is fine for simulating their parts
more accurately -- is there a reason to shop around and
actually _select_ someone else's parts for some application
reason. And in what cases would you not bother wasting time
shopping around and for what other cases would you decide to
spend the time, because you know enough about how they are
made and what differences that can make to be worth that
effort to test and verify when making a selection?
