This is the error message, how I can fix it.
WARNING: Node NC_01 is floating.
WARNING: Node NC_02 is floating.
WARNING: Node NC_03 is floating.
WARNING: Node NC_04 is floating.
WARNING: Less than two connections to node NC_01. This node is used by M1.
WARNING: Less than two connections to node NC_02. This node is used by M2.
WARNING: Less than two connections to node NC_03. This node is used by M3.
WARNING: Less than two connections to node NC_04. This node is used by M4.
Warning: Pd = 0 is less than W.
Warning: Ps = 0 is less than W.
No AC stimulus found:
Set the value of a current or voltage source to "AC 1."
to make it behave as a signal generator for AC analysis.
Direct Newton iteration for .op point succeeded.
Date: Thu Feb 27 12:42:34 2020
Total elapsed time: 0.188 seconds.
tnom = 27
temp = 27
method = trap
totiter = 25
traniter = 0
tranpoints = 0
accept = 0
rejected = 0
matrix size = 14
fillins = 10
solver = Normal
Matrix Compiler1: 73 opcodes
Matrix Compiler2: 1.39 KB object code size
tnom = 27
temp = 27
method = trap
totiter = 25
traniter = 0
tranpoints = 0
accept = 0
rejected = 0
matrix size = 14
fillins = 10
solver = Normal
