Samuel said:
As mentioned before, I didn't install the system- a security company
installed it. Face it- most of the guys installing these systems
might have graduated from high school and, believe it or not, might be
able to read. But typically they have no knowledge about the
equipment's electronics.
Ever heard the term "trunk slammer?"
The techs I work with all have electronics training either through trade
school, regular college or the military. New hires had to pass a basic
electronics knowledge test before they could even be interviewed.
Get over yourself. Wait, I'll help.
So you are saying that you knew the system was installed by morons and
even though you recognized that a device had been installed in an
unsuitable environment you did nothing to correct this danger to your
family's safety but hack together a substitute power supply.
Yep... you da' man.
I love playing with alarm systems and am greatly amazed at the
stupidity of installers. Too bad if that offends you guys but stop
ripping people off with gadgets that don't work....like.....motion
detectors that aren't sensitive to pets....and aiming motion detectors
at heating devices.
I'm not offended - I like to think I do my job very very well. Folks
get what they pay for. You can go cheap and hire a company that trains
pin-heads to screw devices to the walls and then sends them out with
pre-programmed panels to slap in as many systems as they can in a day -
or - you can pony up and hire a company that uses techs who know what
they're doing.
And... If the customer wanted to leave their relatively small pet
running around their house while the system is armed, then wouldn't they
'want' a motion detector that wasn't sensitive to pets?
Well, to put it bluntly.....ever hear of "smoke in a can" or just a
smoking paper towel? You, didn't mention the method you use to test
detectors. I test all of the detectors in our house once per month.
Yes, once per month. Also....have you ever used a hair dryer to test
the heat detector elements?
Yes, I've heard of 'smoke in a can' and I did mention the method I use -
ever heard of 'smoke-check'?
As for heat detectors, I think the 'Miyagi method' is the coolest way to
do it.
BTW, when the NFPA 72 talks about testing of heat detectors, they don't
mean with a hair dryer.
