Looking for pins for "daughter" board standoff
DaveC
Looking for a source of pins to connect 2 PCBs.
An obsolete relay needs to be replaced with a modern one with different form
factor and pin layout. The new relay will be mounted to an adapter PCB and
this PCB will be connected to the old relay through-hole pattern via long
solder pins.
I seem to recall pins that have a larger diameter "shoulder" that fit snugly
into a 0.1 inch hole for soldering.
It's these pins that I can't seem to locate. I'm sure it's because my search
terms aren't very efficient.
What are these called? A link to a Mouser or DigiKey page?
Thanks.
Joerg
solder pins.
They were sold as "solder post" and sometimes "solder pin". I have some
silver-plated ones from way back when but much too small for your case.
Are you sure about the 0.100" diameter? That's rather massive and almost
guaranteed to be a custom order. A machine shop can make those.
Rich Webb
solder pins.
If you're thinking of what I think you're thinking of, you mean 0.1"
*center* holes -- i.e., the PCB holes for the .056 wire-wrap pin size --
then check Digikey (or Mouser or ...) for items in the Vector line. In
Digikey it's Vector -> Prototyping Products -> Accessories. Also pins
for smaller (.042") holes and other handy gadgets.
Many are non-stocked items but might give you a pointer to a part number
for further searches.
..025" wire-wrap pins, on .100" centers?
Rich Webb
Dang. Yes, of course. No excuse, either, since I had the digital
calipers and some wire-wrap pins (used on a protoboard) sitting on my
desk at the time. ::sigh::
That happens. ;-) I added the '?' because there were at least two different
sized WW pins (though .056 on .100 is pretty big).
Martin Riddle
different form
and
long
solder pins.
snugly
search
Thanks.
Collet pins?
No wait....
Solderless Pressfit PCB pin
<http://www.mill-max.com/pin_rec_cat...L&mountingfeature=PRESSFIT&mountinghole=0.057
(1.45 mm) &bodylength=&search=&pr=pin&stagecode=>
Or mill max 0995-0-0-15-00-00-03-0
Cheers
