Hello
I am trying to find a couple of odd relays and was wondering if anyone can help.
1. Need a relay that will close momentarily when control voltage is applied.
2. Need a counter relay (or other component) with a reset switch/button that will only allow closure 3 times before needing to be reset.
Both need to be socket type for DIN mounts.
Project info:
I have a burner controller relay module for a flame effect. There is a 5vdc remote reset line that works only when temporarily grounded. There is a 110VAC alarm out line that I want to use to power a relay. The remote reset will reset the alarm out also. So what i need to happen is: when alarm out is energized, remote reset line is momentarily grounded. I also want this to only happen a max of 3 times for safety reasons (hence the #2 relay/component)
I have been online for a while looking at different relay manufacturers websites and I can't seem to find what I'm looking for, so if anyone out there has any ideas and can maybe point me in the right direction I would humbly appreciate it.
Project info:
