Referring to the schematic as posted by Bertus, if that is what you have built then perfom the following, if not, can you sketch out what you have actually done.
Firstly, disconnect the input ground connection from the ground connection used for the rest of the amplifer and take it direct to the power supply ground.
Secondly, discard D1, Rm and Cm and then connect pin 8 to the amplifier ground.
Thirdly, capacitors Cs1 and Cs2 must be connected as close as is physically possible to the power supply pins of the amplifier.
Lastly, The ground connection for the amplifier needs to be as robust as you can make it.
Try these one at a time so that you will know which one (if any) eradicates your problem
