LM350 Voltage Regulator Kit
  • Thread starter biddy67@gmail.com
D from BC
I'm planning on building this little device to reduce output voltage
on 18v LCD power packs down to 12v.
http://www.national.com/mpf/LM/LM350.html#General Description
What wattage rating do I need for those two resistors?
Huhhhh...
The adjustment pin current max draw is 100uA max.
The reference voltage is 1.262V max.
12V
R1
+-----100uAmax>
R2 low
Assuming R1 and R2 are not part of any necessary minimal loading..
How about pick a 10x swamping current through R1 and R2.
10x 100uA = 1mA.
Therefore
P =(12V-1.262V)*1mA = 10mW
R2
P =1.262V * 1mA = 1.2mW
R1
Use 1/4W resistors :p
It'll take me longer to figure out how low the current can be through
R1 and R2.
D from BC
GPG
Huhhhh...
12V
R1
+-----100uAmax>
R2 low
10x 100uA = 1mA.
Therefore
R2
R1
R1 and R2.
10 mA max, p3
mpm
They are just programming resistors, with high enough resistance that
they pull neglible current.
1/4 watt ought to work fine.
But you know, have you considered learning switching supplies?
(instead of linear).
Pretty soon, you won't even be able to sell linear widgets in
California (USA)
The problem is they waste power due to their inherent low efficiency.
Note: Several power-plant's worth with enough linear devices
considered!!!
So why not bite the bullet and tackle a switching design?
I suggest the LM25576, which you can design online here:
http://www.national.com/pf/LM/LM25576.html
If you can settle for 1-amp (instead of 3A output), the LM2575T is a
very simple design.
For 12 volts, they even have one that has the programming resisitors
already set inside the package. But for the variable one, you would
still add the 2 programming resistors as above.
Anyway, I think the LM2575T is ideal if you want to learn about
switching supplies.
At 52 kHz, it's easy enough to scope, and layout on a PCB without too
much noise trouble. You'll need a coil and a couple filter caps. And
a fast Shottkey diode, but that's about it.
Good luck.
-mpm
D from BC
10 mA max, p3
That's the min load current spec = 10mA. :p
I think that's to provide best internal bias levels within the LM150.
That doesn't mean the min current through R1 and R2.
If there's a load >=10mA, then the sense resistors don't have to be
part of the min loading and can draw less current.
D from BC
this is simple but i will not tell you nunbers. the pot is 0 then 1.2v/240= I
The pot is max then IX5k= v now you got I and V WHAT IS THE POWER.?
