www.alldatasheet.com ----then just follow the pin configuration, input, ground and the output 5V, dont forget to insert 500 milliampre fuse at input pin
Being an amateur does not mean you have to remain ignorant. Read the datasheet. Try to understand what it says. Look at the example circuits the datasheet recommends. Then come back here to ask questions. If you are here to learn, we will try to teach you. If you are here looking for someone to hold your hand and do your thinking for you, please find a forum that does that. This isn't the one.
How do you think a 500mA fuse wil work with 3A output current?
The LM350 is a linear regulator, therefore input current >= output current ( by 50~100µA for regulation) and the fuse accordingly has to be rated at 3A or higher.
