Hello Everyone,
This is for the first time am posting here, ans hope ill get a solution from experts like you guys.
First of all i must tell you that am hobbyist and dont know much.
I have built a LM338 power supply using 12-0-12 1Amp transformer and diode (IN5399) bridge rectifier.
Also 2200uf 50v cap + 0.1uf ceramic cap, LM338 with nice big heat sink, 220ohms 1watt resistor (between adj pin and out pin), 10K pot (also tried 5k 1watt pot), 1K load resistor with LED and 0.1 ceramic cap.
Everything is working fine except 1 thing. I am getting 30v max as output BUT cannot go below 7v.
I turned pot to its very starting position but not showing below 7v.
7 volts is the minimum output voltage showing.
As per data sheet LM338 should produce 1.2v as minimum volts.
Please see the attached diagram of same circuit.
Please guide me where am wrong.
Help me please.
Thanks in advance.
Help me please.
Thanks in advance.
